Charging Batteries from Batteries part 2. Free Energy?
Started by dandman, April 19, 2011, 10:21:33 PM
pese
IG this unloading (for 15 seconds) = 0,125 W/h  are only an small part from the energy of ean BIG car lead battery (with 1000W hour (1kw/h, so  the relation  of the lost energy (unload 15 seconds" it it NOTHING. (a 1 /10000 part !)
If you have used (example) 12V 2,2AH batteries . I will wonder, and think about it.
Pese
dandman
Update. 3 batteries, closed circuit, a mix of series and parallel connections using resistance, passing .8 of an amp for 5 days. Still maintaining a swing in voltage in turn of .05 of a volt within the same range. WOW
pese
Quote from: dandman on April 20, 2011, 05:10:06 PM
Yes,  with higher voltage, you can charge one battery,
but you unload 2 batteries.
So you compensate the lasses (mor than 20%  that needs !!)
in SUMMARY,  anytime you find LOSSES!
Your IDEA is "fine",
but infortunatly it give not an practical, usuable solution to find (this way) :overunity.
Pese
FatBird
This is probably how he is doing it.
It is claimed by some that this is the method Tesla used to run his electric car continuously without charging.
pese
this ideas, are over years in the net.
this cant work.
unfortunatly it produce only LOSSES !
Tesla car system (also made from others in 1930+odd
and some years ago (in eastern europe)  have nothing to do
with recharging DC.  Tesla used an special AC Motor, made by Westinghouse.
Pese
