Car Running on Water to be Released May 4th at 10pm EST (USA)
Started by evolvingape, April 29, 2011, 06:19:45 PM
ElectricGoose
Quality input there Evolving Ape.  Good material on the turbines which can be very efficient even without 'alloyed' fuels.
Flame on!
evolvingape
Following on from the previous conversation I have had a chance to sleep on it and believe this might interest you all...
If we were to utilise the plastic to oil technology to make our own oil then we would have a hydrocarbon liquid with different properties, depending on what plastics we put into the “sauce mix”.
If we were to utilise a solid state mixer just prior to injection into the chamber then no emulsifier would be required, simplifying things massively, as we would not need an additional raw material and there would be no problems with changing the recipe.
The image I have put up is from this page:
http://en.wikipedia.org/wiki/Injector
Anyone recognise its operating principles ? You should because it works the same way as the HELIS, in mechanical only mode without an electrolytic closed system crossover function.
http://www.overunity.com/index.php?topic=10218.0
So it will be very simple to make your own with off the shelf components and stainless steel hydraulic fittings.
I would suggest that the motive fluid is the water, powered by a water pump, as it will have the necessary mass flow rate we require.
The entrained suction fluid would be our oil. I would suggest some kind of metering valve such as a needle or butterfly to control the oil mass flow rate which will change depending on the viscosity of your sauce mix. It will also allow you to adjust the power of the engine from the “cockpit” if you remote control it.
If you had a “Mr Fusion” on board for emergencies and you ran out of fuel, you could strip the dash or the bumper off and make some more to get you out of trouble. You could also go find some ground water to refill the water tank.
So any thoughts ?
RM :)
ElectricGoose
Evolving Ape
Yes, I have considered the emulsion with the emulsifier and this has been accomplished.  Really this whole thing is only limited by how complex or simple you wish to make it.
Emulsifiers have the problem that if you don't chose the right one, they will leave a residue after burn.  Additionally, if you dont get the formula correct there is the worry of separation if stored for prolonged periods.  Mixing in some prechamber as you suggest gets around both these concerns.
The bottom line is....don't get bogged down with huge design issues. Start with something and work from there.  You KNOW that oil + water in a 50:50 ratio when hitting a hot surface will immediately 'flash' into a expansive superfuel far more volatile than oil or diesel by itself.  Make this your bench mark.
If you have a little diesel engine that you can experiment with, the simplest way to circumvent emulsifiers is first making sure that the fuel pump is in order and will handle a water/oil mix.  After that, anything as simple as 'blending vortex' chamber prior to the fuel pump and primarily the INJECTOR RAIL is where you will want the mixing of water and oil to occur if you don't include a binder.
If you agitate/whisk water and oil enough until the oil 'beads' are very small, they will actually stay in solution long enough without the emulsifier to make it through to the injector rail.
evolvingape
Hello again Mr Goose,
I have done some further thinking on our discussions and I now wish to share with you my current direction...
For me emulsification technology is a no go. I mean absolutely no disrespect to you, your work in this regard is admirable, but it fails my criteria.
The reasons for this are that an emulsifier requires a stable raw material, acceptable quality control, a continuous support structure, and considerable R&D. It is also suited more to mass production than on demand supply.
All of these are outside the resources of the common man. My aim of the game is to provide technology that does not require me and my specialist knowledge. A failsafe mechanism if you will.
So, I have worked upon Injector technology and come up with my Injector Mk1.
This utilises off the shelf stainless steel 316 fixed female tees, sleeving technology, ECV inserts and diffuser technology.
Water pressure is generated by a pump and forced through the ECV, oil vapour is sucked in under vacuum just before the area of maximum compression, and is then propelled from subsonic to supersonic.
This supersonic velocity soup is then forced through a 10 Micron Gauze causing atomisation (or close too), before being fed to the Injector Rail.
Note that I have inverted the Oil Vapour Inlet, this is to prevent on shut down water entering the oil boiler.
This design also removes the need for a condenser chamber as with the standard plastic to oil technology. The condensation of the oil vapour occurs upon vacuum suction into the water stream just before the area of maximum compression.
This means all we now need to do is melt the plastic in a stainless container, simplifying the architecture, and the vapour gases are sucked into the injector, not liquid.
Control the mix by controlling the injection hole diameter. For prototyping start small and then simply drill the next size up and compare performance until optimum is achieved.
With a plastic boiler installed in the boot of the car and the fuel tank of the car filled with water instead of petrol it should be a simple retro fit.
RM :)
ramset
RM
Waste plastic is a monsterous Problem!
Turning it into a resource such as a fuel woulsd be "HUGE"!
The idea of setting up a supply line for recycling in this manner would be very appealing!
The "Processer" and the troubles associated with it are the weakest link in this?
IMO the place to start is there,get a good reliable "reactor" the rest will follow![This would be Oh so Cool!:=}
BTW Mr.Goose
I have to say That 50/50 bench mark you speak of [to start]
Very Cool,
I picked up Half a dozen old VW 1.6 diesels recently,Might play with a
bit of "soup"!
Have you got a "Recipe" to start the ball rolling?
Thanks
Chet
Thanks Grandma
