Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
0 Members and 247 Guests are viewing this topic.
conradelektro
Quote from: TEKTRON on May 26, 2011, 03:41:44 PM
Conrad, looks interesting but what keeps the toroid from pumping power into the other gen coils?
@TEKTRON, nul-points, Stefan:
The critical factor is exactly the influence of the generator coils on each other via their "feed windings" on the toroid.
The "pick up winding" does not pose a theoretical problem (in my opinion).
And I hope that all generator coils and their "feed windings" just swing along unisono. Meaning, that all coils (generator coils and feed windings) swing at the same frequency and at each pulse (complete sine wave) only one pair of generator coils feed in "power" (via the "feed winding" they are connected to).
The big question, do the generator coils which are not energized by the passing magnet (all but one pair) dampen the power put in by the energized generator coil pair to the toroid significantly?
I guess, only the experiment can show the way forward.
Greetings, Conrad
P.S.: I am waiting for the delivery of a 4 mm Phenol Hartgewebeplatte PFCC201 ca. 500 x 250 mm
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=160446209722
I could mill a few fairly good round disks and drill holes at exact angles with a dividing head and a press drill. These tests were done with acrylic.
nul-points
Quote from: conradelektro on May 27, 2011, 01:32:23 PM
Greetings, Conrad
i look forward to hearing any results with interest
good luck, Conrad!
np
http://docsfreelunch.blogspot.com
teslaalset
I found an interesting article from Steorn on using a stationary and a moving magnet at both ends of a ferrite rod.
Mind the results of Experiment 4: asymmetric Non-linear MH.
Might have some relation with RomeroUK's findings...
wings
Quote from: teslaalset on May 28, 2011, 07:07:35 AM
relation also here?
http://books.google.com/books?id=iwEAAAAAMBAJ&pg=PA102&lpg=PA102#v=onepage&q&f=false
http://www.overunity.com/index.php?topic=3500.3690;wap2
http://www.tcs-access.com/sensor/english/wiegandeffect.htm
http://www.tcs-access.com/sensor/english/4129800.pdf
http://www.borderlands.de/Links/PSMM%20-%20SPESIF%202010%20-%20Valone.pdf
The Wiegand effect is a macroscopic extension of the Barkhausen effect as the special treatment (twisted like litz?) of the Wiegand wire causes the wire to act macroscopically as a single large magnetic domain. The small high-coercivity domains in the Wiegand wire outer shell switch in an avalanche, generating the Wiegand effect's rapid magnetic field change.
teslaalset
Quote from: wings on May 28, 2011, 10:15:23 AM
relation also here?
@Wings,
After reading http://en.wikipedia.org/wiki/Wiegand_effect I don't think there's a relation.
But still an interesting effect!
(the patents at the bottom of the wiki page show nice details)
