dont laugh, i astral traveled and saw the first mass recognised overunity device
Started by gigastorm123, June 06, 2011, 07:22:36 PM
Shokac
Hi!
If you connect the red and blue wire to the HV, a copper tube to +400V DC must get a large amount of free electrons, which collects on the copper itself.
energia9
Quote from: Shokac on June 11, 2011, 05:51:30 PM
Hi!
MW383
Quote from: gigastorm123 on June 06, 2011, 07:22:36 PM... its a 1/4" thick copper tubing wraped into a large coil shape and inside the tubing are two wires, one blue, one red. then i saw a pvc tube be put through the copper tubing coil with the wires inside, and then a thin strip of stainless steel woven ribon, [like bunches of littlle wires are woven to form a ribbon like they do with leather belts] was once wrapped through the center of the pvc pipe and came out on either end, then either connected [soldered] to the ends of copper tubing coil [most likely to create some kindof resistence path sortof thing going on] or it just wrapped around the whole thing.....
Ok, not laughing. Here is why. I have experimented last year with a similar construction for Nathan Stubblefield coils of all things. These style coils you describe are incredibly easy to construct and always result in a very neat/organized system. Which in my belief is important when considering magnetic fields. I will reflect on the potential properties of this particular device and if I come up with anything useful, will post further. Keep describing this and drawing pictures if you can. I will have to dust off my former research and dig out my prototypes. I had put all of this down as I didn't expect to continue with any of it. But now my interest is re-sparked to a degree. Cheers...
energia9
we need to spend some time exploring this area as not many had tried these be4 i think...  i experimented with the pic i posted above,  and my opinion is that the coil has to work as a step down transformer but as a rectifier at the same time...like a vacuum tube...  may sound crazy but im actually thinking of heating the Ozone gas up to a higher temperature,  we have to try every possible thing in this unresearched area....
thanks for your image  Shokac
