gyulasun
Quote from: Magluvin on September 25, 2011, 12:09:55 AM
Lonny Like.   ;]
Cheap too.  What do you have for wire/turns?
Mags
The AL value for the TX36/23/15 3E5 type toroidal core is 11400nH/N2
This gives about 811 turns for the 7.5 Henry measured inductance
(formula is N=(L/AL)1/2
811 turns sound very much and probably filled up almost all the inner diameter or the toroid core. The 4.4 Ohm DC resistance for the 0.8mm (I considered 0.812mm for AWG 20 which has 33.31 Ohm resistance for 1000m length) copper wire gives about a wire length of 132 meter. Is this more or less ok, Luc?
Gyula
Overunityguide
Quote from: Magluvin on September 25, 2011, 12:26:59 AM
Just thinking about it, this may be able to breath some life into a microwave transformer. Just need to find the freq of operation.  ;]
Mags
@Magluvin,
It depends on what Inductance / Impedance your secondary coil of this microwave transformer has... For sure it has to be high... But with my setup I am limited to 950 Hz, because that is the upper limit of my frequency drive controller.
But when you can go higher than 950 Hz, than your inductance / impedance of your secondary can be slightly lower, but still it needs to be way higher than the primary coil. But the laminations for higher frequencies needs to be also be thinner.
Mags, do you know what a normal inductance value would be for the secondary coil of a microwave transformer?
With Kind Regards, Overunityguide
Most Recent, Regenerative Acceleration Effect inside a Transformer:
http://www.youtube.com/watch?v=2YiRV1SUsgc
gyulasun
Quote from: Overunityguide on September 25, 2011, 04:52:09 PM
It must be in the several Henry range.  A google search brought this:
primary L=68.2mH
HV secondary L=15.5H
(from this link: http://sci.tech-archive.net/Archive/sci.electronics.cad/2008-02/msg00082.html )
Maybe the laminations could work up to some hundred Hz for the older type transformers (nowadays there are ovens with switch-mode power supply to get the HV too).
Cheers,  Gyula
PS: just recall this pdf file member poynt99 uploaded that includes info on oven transformer, page 17:
Primary: R= 0.35 Ohms; L= 44.4mH
Secondary: R= 88 Ohms; L= 19.3H
(from this: http://www.overunity.com/index.php?action=downloads;sa=view;down=209 )
Overunityguide
Quote from: gyulasun on September 25, 2011, 05:33:04 PM
primary L=68.2mH
Cheers,  Gyula
Ok, thank you very much
With Kind Regards Overunityguide
gotoluc
Quote from: gyulasun on September 25, 2011, 03:40:29 PM
Gyula
Hi Gyula,
I had to pickup my Digital Caliper from storage to re-check the diameter of the wire. It is actually 0.50 mm with enamel coating. The DC resistance is correct @ 4.4 Ohms so you should be able to figure out the wire length and approximate amount of turns.
Let me know if something does not look right.
Thanks for your time
Luc
