0 Members and 23 Guests are viewing this topic.
gotoluc
Quote from: gyulasun on October 16, 2011, 05:40:53 PM
You wrote: I found that it's only @248Hz that there is Zero Phase Shift when under Load. See Second Shot below. Frequencies above 248Hz the Phase slowly goes up and below 248Hz Phase slowly drops.
My question is where do you mean exactly the zero phase shift happens at the 248Hz frequency?
Humm :-\... lets try it this way. If I connect the Primary of the Transformer I made to the output of my Signal Generator to find the Frequencies that when I connect the load to the Secondary it does not consume any extra current.
This happens at 248Hz. At lower Frequencies it slowly starts to consume current and at higher Frequencies it slowly starts to reduce current consumption.
Now when doing the same as above but using the Scope to only look at Phase ( scope adjusted like fist and second shot) I can see at 248Hz there is Zero Phase change when adding the load or removing it.
Now, if I start to lower the Frequency it slowly starts to shift in a negative way (reducing phase degree)and if I increase the Frequencies it slowly start to shifts in a positive way (adding phase degree)
This is what I mean with a Zero Phase Shift Frequency.
I hope you understand as I don't know how to explain it any better. I would have to do a video ;D if you don't get it.
According to Thane, a 90° phase shift is the goal between the input current and voltage. This is a situation when input power is fully reactive and in case this happens at the 60 Hz mains frequency than utility WattHour meters in most homes would not measure the load's consumption.  Of course reactive current would still load the mains and this reactive current should still be supplied by the utility providers.
I agree to the above but I don't think it's possible for a transformer Primary to not consume any current, so I don't think you can start at 90 degrees Phase Shift. That is what I've been trying to say. However, from my tests I do see that it's possible to build a Transformer in a way that when the Secondary is on load it will not shift the Primary Phase to a lower degree. This I have proven with my tests with special core. Please correct me if I'm wrong but as far as I am concerned there are no low Impedance Transformers that you can take off the shelf and have these results.
Considering your question on the 40.5° phase angle: it does not represent a fully reactive power like it would when the phase angle were at or very near to 90° angle.
I agree but like I said above, I don't think a full 90 degree shift could be achieved. I hope I'm wrong but I have not seen it yet.
Phase angle, Phi = arctan(XL/R)   so if you have R=120 Ohm and a coil's inductive reactance XL=150 Ohm at a given AC frequency, than the phase angle between their current and voltage is arctan(150/120)=51.34°  arctan function is available in Windows built-in scientific calculator and click on Inv icon inside it when wish to take arctan. (the 120 Ohm is the coil's DC resistance)  So in this example we have both a reactive and a real (heat) dissipation for this coil. If you had a coil which would have say XL=800 Ohm at an AC frequency and it would have only 1 Ohm DC copper resistance, its phase angle would be arctan(800/1)=89.92° so pretty close to 90° an almost ideal coil.
This arctan calculation sounds very interesting. At what Frequency do you think you would get 800 Ohms Reactance?
Could you calculate heat dissipation (losses) in my Primary @248Hz Sine Wave with DC R of 17.2 Ohms and L of 220mH
Thanks for your time.
Luc
gyulasun
Hi Luc,
Ok, now it is clear how you meant the zero phase shift occuring i.e. not occuring...  :)
QuoteI agree to the above but I don't think it's possible for a transformer Primary to not consume any current, so I don't think you can start at 90 degrees Phase Shift. That is what I've been trying to say. However, from my tests I do see that it's possible to build a Transformer in a way that when the Secondary is on load it will not shift the Primary Phase to a lower degree. This I have proven with my tests with special core. Please correct me if I'm wrong but as far as I am concerned there are no low Impedance Transformers that you can take off the shelf and have these results.
Yes, a transformer will always consume at least reactive current and the less copper and core loss a transformer has got, the closer the phase shift would be to the ideal 90° phase shift. When you start loading it, surely you can find a frequency where this phase shift would not change due to the load but the same reactive current is still consumed by the primary coil. I do not know if such a low impedance transformer exists off the shelf, the frequency you test it is always a question and what purpose a specific transformer was manufactured for.
QuoteThis arctan calculation sounds very interesting. At what Frequency do you think you would get 800 Ohms Reactance?
Well, the formula to calculate the frequency where a coil can have 800 Ohm inductive reactance is f=XL/(2pi*L)  i.e. f=800/(6.28*L)
For your 220mH coil the frequency where you would have 800 Ohm inductive reactance would be f=800/(6.28*0.22)=579 Hz  However, the 17.2 Ohm resistance would "ruin" the phase angle a little:  arctan800/17.2=88.76°phase angle would be involved so an even higher frequency should be found... At 9 kHz the 220mH coil has an XL of 124344 Ohm reactance this gives a phase angle of 89.99° with its own 17.2 Ohm wire resistance...
From your third scope shot the current via your 220mH primary is 0.0177A this is what is established by the series 10 Ohm shunt and the inductive impedance of this coil at 248 Hz. This current dissipates PL=0.0177*0.0177*17.2=0.00538W power i.e 5.38 mW loss in the coil.
Gyula
Overunityguide
Quote from: gyulasun on October 17, 2011, 05:52:16 AM
@Gyula
The Primary coil resistance is 1.8 Ohms in my MOT transformer experiment...
This is exactly why I am using a MOT transformer to do this kind of experiments.
My MOT High Freq. (Delayed Lenz) Experiment:
http://www.youtube.com/watch?v=-j3-x3JJDA4
And Yes Reactive Power will be consumed, but in my opinion this is a nonissue, because we always can power factor correct this.
With Kind Regards, Overunityguide
gyulasun
Quote from: Overunityguide on October 17, 2011, 07:46:52 AM
Yes, high power mains transformers in the half to the 1-2 kWatt range have primary coils made from thick wire, so copper resistance is not the main problem.  However their core laminations can have upper frequency limits  that may prevent them to get meaningful power output because losses above some hundred Hertz or in the very low kHz range become prohibitive. Perhaps the so called Hypersil cores do not suffer from  as much frequency limitation as the laminations with normal 4% Si content.
And I assume your MOT's primary may serve as a "coupling coil" to the very high impedance secondary coil.
QuoteAnd Yes Reactive Power will be consumed, but in my opinion this is a nonissue, because we always can power factor correct this.
Yes this is what would be the most welcome tests and looking forward to seeing such tests where really useful output power can be received at the output and the big question is: at what input power price?
Thanks,  Gyula
DeepCut
Quote from: CRANKYpants on September 11, 2011, 10:28:10 PM
Hello Everyone,
The coils employed in this prototype are 4.5 ohms, 16 gauge bi-filar wound series connected with M1 core laminations and create acceleration at 1800 RPM with a 10 ohm light bulb. Each coil can produce 50 Watts or more and the magnets are 90 lb pulling weight. They create so much torque and acceleration that two set screws on each rotor were not enough to keep them secured to the drive shaft and they had to be returned to the machinist to have key-ways installed. Even now the air gap on each side is about 1/2 an inch. When properly balanced with three rotors and offset cores the cogging torque is virtually zero and the core "cost" was very low - which is reduced as speed increases anyway and is NOT an issue.
http://www.youtube.com/user/ThaneCHeins?feature=mhee#p/u/4/u3gVfltiO-E
I will post the test data when I find it to end this discussion (which is a waste of time BTW) because all generators have coils and cores with some hysterisis losses inherent in them but not all generators accelerate when a load is applied which is the REAL issue.
Cheers
Thane
WOW Thane,
i'm just catching up on bits of this thread.
4.5 ohms @ 16-gauge is 9.5 pounds of wire, crikey !!!
No wonder you're getting 50 watts :)
I've got hold of a MOT so i may join you chaps on that journey soon.
In the meantime i've been watching ALL of Thane's youtube videos (all 62 of them !) :
http://www.youtube.com/user/thanecheins
It's a very sound and logical journey, it's very interesting seeing the concept go through it's stages of development and i recommend that everyone views the lot of them.
If you use FireFox and want to download them all in one go then i'd recommend this plugin :
https://addons.mozilla.org/en-US/firefox/addon/bytubed-bulk-youtube-video-dow/
Best to all,
DC.
