Farmhand
I agree with DeepCut, Synchro1 if you want your OU claim to be taken seriously then you'll need to show proper in out measurements or
self run with capacitors gaining charge. Battery voltages mean very little or less than nothing. Normal batteries gain voltage while under
significant load during some periods of discharge, the battery is still outputting energy when the voltage is rising. Don't just believe me people
try it for yourself. Take a Lead acid battery in good condition and fully charged, then load it with a reasonable load and watch the battery voltage
initially drop then rise above the lowest voltage it dropped to, so the battery voltage rises while the battery is under load. I can't say all batteries
will do it, for best effect the load can't be too much or too little, it should be reasonable for the load eg. a car battery like in the video 2 to 5 amps
or so give or take a bit. At first the battery chemistry can't keep up with the load and in trying to equalize the chemistry with the load there can be
an overshoot effect. This is just one battery effect all kinds of funny things can happen. Batteries can increase in voltage while supplying a load = Fact.
It's difficult to show on video because it takes a while to happen, try it and see. That's why in out measurements done accurately or self running without batteries
and a rising capacitor charge is a good idea. If running from caps and the charge is becoming less no self runner.
Here's a joke video I made about it,
http://www.youtube.com/watch?v=SFNLxCvOim8
And the reveal, the voltage drops to 12.30v initially under load then rises to 12.36v while still under the same load, which is normal battery behavior.
http://www.youtube.com/watch?v=uTv0n1bS35E
Anyway Synchro1 where is the claimed extra energy coming from ? If there is extra energy entering the system you should be able to identify
where it is coming in and how much.
Maybe you have OU maybe you don't, but myself and many others are tired of hearing the claims with no will to share the hard evidence.
Cheers
synchro1
@Farmhand,
                It's not my intention to claim overunity, but to demonstrate the deleyed Lenz effect. I get acceleration and decreased input under load. You know what happens to the battery when I disconnect the load?  What do you think of the See-Saw charging effect? i'ts a millivolt per second exchange. When that harmonic cycle commences, there's no longer any power depletion from the battery. I don't care what you have to say about batterys, this Motor Alternator, Battery oscillation , power recharge cycle,  has to balance. The audio track's the data not the multi meter. Piston like, alternating power surges, self modulating, too and fro, factor out any additional input. That demonstrates that the system has achieved unity. I know that batterys have a mind of there own. The super fast neo sphere has slipped the surly bond of Lenz drag, and the Battery and Alternator go into a charge recharge resonance that is the earmark of "Unity", and proximate confirmation of Lenz delay.
There's no extra energy coming into the system. We played a trick on entropy, and recovered primary flyback as OU factor.
PiCéd
In fact, we should see the speed of the motor when no ferrite core is next to it and then compare the speed with a ferrite core and coil on it, if the engine accelerates more with the ferrite and coil than without  it may be possible to have O.U.
Well, it is something like this.
DeepCut
Quote from: synchro1 on March 29, 2013, 06:56:45 AM
@Farmhand,
                It's not my intention to claim overunity ...
And yet :
"That DC motor must consume some watts. My self looped 2" 100% COP Spifilar coils Neo Sphere would run it for free. I can turn the speed up and still break even. The magnetic gears boost the auxilliary spheres past Lenz Delay Propulsion Threshold speed. Together the LDP on power and pickup would yeild another lazy 8 OU device."
And here :
"@Deepcut,
             Any amount of horse sense can tell you there's a sweet spot based on JLN'S experiment. Positioning is essential and fished for with a multimeter. Once the neo sphere's inside Lenz Propulsion zone, it's OU."
Make your mind up.
DC.
synchro1
Quote from: DeepCut on March 29, 2013, 02:49:35 PM
And yet :
And here :
"@Deepcut,
Make your mind up.
DC.
I grew infected with a case of Ottowa efluenza! Everything is Overunity! Invention is a science and an art. I work from intuition and express myself by way of metaphor.  You will find out that it's no big deal to run power backwards if you carry through with your magnet core output test. Twinbeard's JAMING the pickup up coil with current of different voltages to induce LENZ DELAY. Those coupled diametric magnet cores induce delay as well by JAMING the induced pole shift a bit differently.
Output gathered by a transformer pickup coil of 22 gauge over 150 Ohms of 34 gauge magnet wire, like Twinbeards, can be fed directly into a second 22 gauge output coil wherein is placed a rotating neo sphere, to JAM the pole shift and induce 'Lenz Delay". Twinbeard says it creates a 'PRETTY ODD FIELD' in his video! So do those core magnets. I looped the output to source through a FWBR, and checked for voltage rise in the power battery to fish for position. This is an important test you're about to run. Prepare youself for future shock!
This approach has the promise of really increasing COP. Unity can be viewed as overunity, if primary flyback is added.
