Perpetual solar self sustainer.
Started by stevensrd1, November 11, 2011, 04:36:14 PM
powercat
HI stevensrd1,
there would be a queue of a mile long of people Wanting to replicate your work,
if you could make it run on a capacitor or a DC to DC converter or a combination of the two.
I and many others have seen too many devices that rely on batteries and ther measurements.
They fail completely when very precise testing is done (not using batteries)
I hope your circuit and solar cell configuration are indeed free energy,
if that is so then  there should be no problem running the circuit with out batteries.
Good luck
the_big_m_in_ok
Quote from: powercat on November 17, 2011, 06:29:18 AM
HI stevensrd1,
Hi powercat,
I had a busy day but I will 'stop in' to say:  I'm ready to redo my hand-drawn schematics for a combination of two previous schematics, starting with this...
http://www.energeticforum/renewable-energy/3235-gray-tube-replication-68.html
(pg. 68, reply #2012, as well as #2014---the spark plug circuits)
        One other thing...the 7.5KV NST drawing in reply #2012 has a 3-way spark gap.   I intend to surround a spark-plug-equivalent with a soup can affair that grounded or else going to a battery through a transformer and a diode so as to reduce radiated EMI as much as possible.   I told this to others awhile ago and was met with skepticism on their part.   They said something about a Faraday cage had to be perfect to be effective.   Xenon tubes produce EMI and are used all the time at night at airports, in the rain and in fog.   Emergency flashers for highway road use as well.
My bottom line goal is to provide emergency lighting indefinitely in a power outage and allow some use of peripheral electrical/electronic appliances to be utilized in the light shining.   It needs more work right now.
Later reedit:
It crosses my mind that an arc welder produces a non-stop crackling, buzzing blue-white arc that's loaded with ultraviolet light; too bright to look at with your bare eyes and not let the light sunburn your retinas.
     Where's the BEMF as it returns to the transformer(s) it came from?   Is the work surface grounded so as to soak up the radiated EMF?
--Lee
stevensrd1
here is some updates on the perpetual solar sustainer and overunity pulse motor. http://www.youtube.com/watch?v=XVSvqT0YrxI
the_big_m_in_ok
Quote from: stevensrd1 on November 11, 2011, 04:36:14 PM
A vid on my perpetual solar self sustainer, http://www.youtube.com/watch?v=i5K11dCgulY
stevens...
As a slightly off topic point:
http://www.youtube.com/watch?v=tJvCEMIF5EU&feature=related
I didn't know this could happen.  Your salt water battery has enough power to self-electrolyze water to H2-O2 by itself?!?!  Those chemical bonds in water are pretty strong to say the least.   That's why the HHO experimenters shouldn't even contain their output gas in any pressure vessel.   Shock sensitive explosive!
Eventually the salt water battery will go dead.   Have you times the gas production action until it quit?   Do the HHO people know about this?
--Lee
stevensrd1
yes it works like an electrolytic cell,,and by connecting the positive and negative to itself it uses its own power to cause water electrolysis.. So no external electricity is needed. The key is in using the magnesium electrode that is 99.99 % pure. As to how long it self power and supply the gases, no idea, I have not ran it more then say two hours at best guess, it was just something I thought I should put out for others to experiment with.
