Overunity and... more, a lot more
Started by ivaeugen, December 13, 2011, 07:26:48 PM
ivaeugen
lost phisics or maybe dooms day
One month ago, i have rediscovered the idea of perpetual move, idea common to each and every child when discovering science. However, this idea is strongly, rapidly and quite brutally inhibited by the science teachers.  As the child from within has not entirely disappeared, I search the internet to find out the others way of thinking and also if there is any chance for me to go anywhere....  lot of stupid things there!!!  But, among these stupid things  i have started to notice at least odd facts. in this way i have reached the UFOs, aliens....which led to legends and signs. Story is long  but to cut it short I have reached this point with overunity: Ö®, ∞, ♀, â™,, which is: (picture from botom page)
There is talked a lot about fast spinning red mercury â€" I'd bet there are mercury vapours in inert gases with a red light. Mercury is not magnetic but it can be polarised ... so some researches are saying that mercury can be magnetic for short periods of time when the particles are hitting each other and exchange electrons. So it can be magnetically polarised and if something external triggers the system, the particles from the tube within will be hitting  each other frequently and it will occur the magnetic polarisation .
This idea has made me 3 days ago to return to the initial idea of magnetic motor. Here i have associated "droje" which has a very interesting signalistics asociated -  it  looks like 2 concentric coils with  another coils cross like between the first 2 coils and a triphasic rotor (david star) in the middle; so everything seems to focus on a single central atom; the 2 coils are generating a vortex - double helix... i think that the entire device is trying to dismantle in a very controlled way an atom; in this moment i linked that with what Edward Leedskalnin said and done..  there is a long story but i think that the atom can be dismantled very easy if you know how to do it. What i have found out is following: magnetisation is a nuclear process which is modifying the atom structure â€" by taking out the protons from the nucleus and bringing them onto an opposite orbit to the electrons; the magnetic field is not generated by protons and electrons; it is composed from protons and electrons orbiting outside the material .
As the protons and electrons on the orbit and the neutrons within the nucleus,  the nature of the magnetic and electrical current is dual - electron and + proton result in now there can be separated the mass from the energy... quite easily, with 2 coils. Or, there can be added energy and reach  gravity/ anti gravity. If this theory is valid, the antigravity can be easily obtained: almost all elements being diamagnetic there can be over charged: a magnetic wave must be generated by a frequency resonating with the structure of the material needed to levitate the waves must hit the material with the opposite polarity of the earth hemisphere is in... and if it is applied enough energy...  apparently the object will loose weight; if the polariti are applied backwards (opposite with the earth one + with -) the object will apparently gain weight, and if Edward Leedskalnin has done what the legends are telling that he has done with not available a large qty of energy then, probably the process is not very big energy eater ...it looks quite easy and cheap but in the same time very dangerous because any person having some electronic  knowledge and understanding that  + is not just a symbol, ground or something that can be ignored will be able understand that a magnet is an splitter mass/energy and to easy build cheap but very efficient devices able to modifying radically and very easy the essence of our world: mass â€" energy /time (mass and energy affects time)
the contemporary physics needs ad-dons. positive energy, relationship mass-energy/time.
if is true... it is dangerous, and i have spent a lot thinking about telling world about my discovery or not. however if we cannot manage this force...we are still primates and we do not deserve to call ourselves as a civilisation neither to survive.
ivaeugen
i do not understand electronics but i think that i understud what is doing all your dynamo/motors and are builded wrong.
is basically same thing with taking energy from the air with an wire from sky to ground but with compacted device and turbo forced process, you take energy from magnet, now your magnet is in energy vacuum and suck back power from air, the mistake is that you use same magnets to spin the rotor and give back too many... 1st you give back to balance for free and only from that moment giving more will be used to spin the rotor: use a second row of smaller magnets on a larger circle with a single set of coils for motor moment ;)
and another one... ppl are saying in a very important way "radiant energy" but do not really understand the words => all energy is radiant, we have underunity because we need energy in linear way and difference from balance to our randament is used to force energy to go linear
ivaeugen
i think i understood more... a lot more
mass by collapsing is generating energy blow and make mater by combining mass with energy, mater is loosing energy and collapse again, and again, entire galaxy is a big pulse engine and those who build droje understood that and replicated at a smaller scale, droje is achieving overunity because energy is an effect of mass, droje is generating endless energy, you can take that energy and force matter to collapse again and produce more energy... coils from droje are not only to build magnetic field and force a small black hole, are to harvest energy after blow too... the only problem remaining is that who build that is thinking 4 poles... are always 4 different colors alternating in same order.
droje can be translated as essence of everything... maybe replica of essence!?! :D
i think 2 colors are for interacting with energy and other 2 for controling mass, mass must have 2 parts... we need the 2nd part of mass to triger the reaction who generate energy
holy grail... source of supreme power... looking like a box...  "do not tuch directly with your hand" => don't put your fingers in outlet
maybe a storage for this device... or just an old fuse box...
ivaeugen
is posible that in a black hole to be our missing element, maybe those two collors are somehow fake that element and trigger reaction with neutrons and in this way is producied an energy blast and i think that bronze have something to do with
or it may be no second element it may be realy simple, centrifugation, by spining realy fast an atom will separate mass from energy, isolate mass from energy and mass will produce another energy
ivaeugen
how to build a zpm (or at least a good try):
build a gyroscop from PURE iron, coper... put that gyroscope in an donut shape builded from bronze, you can use an ax to spin gyro from both sides, outside the bronze donut use some very basic motor with no contact on moving parts (magnetic bearings) vacuum entire device and... will produce overunity energy for free forever, because when you take some, mass (neutrons) from metall gyro will add to rebalance.
and here is the meaning of do not work against nature but work with nature... nature (of elements) seek balance. at least untill what i sayed before is not prooved with not doubt to not work i'll consider energy problem solved, this is the esence of energy, now everyone will know... it is easy, do not try to do it dificult
