Why there is no measurable electric field in a magnet!
Started by gravityblock, February 24, 2012, 11:48:10 AM
gravityblock
Time should play the part instead of meters or distance.  We should look upon Time as the result of the force that impels a body through space.  The greater the force, the shorter the time, and the shorter also the space to be traversed.  Thus, if the force were infinitely great, time and space would be infinitely small, they would cease to exist.  If the force was infinitely small, time and space would be infinitely great.  But, again the force is not everything, because in reality it does not exist.   All that exists is the impulse that is applied to the body in space and imparts momentum to it.  The body's movement is then only limited by the resistance it has to overcome.  What does exist then is the momentum that arises from the impulse of the force, and not the force itself.  Again this impulse only exists as a function of a Will that gives rise to it.  To sum up, time and space are the outcome of a powerful Will acting on the Universe, that is what we should measure, taking note of its intensity in any given phenomenon.  In our Universe this Will manifests itself as galactic time.
Gravock
gravityblock
I'll be tying up some loose ends in this post.  The maximum allowable photon frequency in the universe is 5.167 x 1062 Hz, either in forward (matter) or reverse time (anti-matter).  The collapse of a photon with the maximum allowed frequency in the Universe will result to a probable black-hole mass at the quantum scale.  This mass is the densest probable created mass in the entire Universe.  If we're inside a black-hole with forward-time (matter) and we change our frequency and/or polarity to the maximum allowable frequency of the universe in reverse-time (anti-matter), then we will be repelled by an infinitely great force.  Being repelled by an infinitely great force would equate into time and space being infinitely small.  Thus, we could travel anywhere in the universe in zero or near zero time.
Gravock
gravityblock
What about the G-forces?
The G-forces can be eliminated. Here's how. Take a flying saucer for example. If the bottom half of the saucer is facing the black-hole (matter) in reverse-time (anti-matter), and the top half of the saucer is facing a white-hole (anti-matter) in forward-time (matter), then the bottom of the craft will be repelled with an infinitely great force while the top half of the saucer is being attracted by an infinitely great force simultaneously. The G-forces will be cancelled. This is how you create and open up a worm-hole throat.
Gravock
gravityblock
This is important to understand. An electron is in forward-time (matter) with negative energy, while a positron is in reverse-time (anti-matter) with positive energy. However, a proton is in forward-time (matter) with positive energy, while the anti-proton is in reverse-time with negative energy. Do you see the difference? This is true since we're in forward time (matter). However, if we're in reverse time (anti-matter) then our energy is reversed relative to the electron-positron and proton-antiproton. Thus, when your inside a wormhole throat, you're simultaneously moving in forward and reverse-time.  In other-words, you're stationary in time, thus there are no G-forces. If you can grasp this, then you won't find any flaws in how to create and open up a wormhole throat.
Gravock
gravityblock
Quote from: Gwandau on February 26, 2012, 09:39:50 PM
Dave45,
This video has nothing to do with what Gravock is trying to convey.
Why on earth do you impose the old Christian guilt complex onto this thread???
Are you a troll?
Gwandau
Gwandau,
Actually the video on Life after death does have something to do with what I'm trying to convey.  With the right energy, a person will be repelled from forward-time (darkness of a black-hole) while being attracted simultaneously in reverse-time towards the light (light from a white-hole).  Time will not pass for you in this state.  This is eternal life.  If a person has the wrong energy, then the opposite will occur.  If a person has a little faith in their creator, then there is no need to build a physical space-craft.  It can be done spiritually.  The physical process is an exact copy of the spiritual process.  There is one important distinction which needs to be made.  The physical process will cut a person off from his creator.  This will lead to a spiritual death.  There is only one way to escape a spiritual death, and that is by being with our creator.
Gravock
