Why there is no measurable electric field in a magnet!
Started by gravityblock, February 24, 2012, 11:48:10 AM
gravityblock
"There is only one Force in nature and this is the Electric Force", Ioannis Xydous , October 2011.
Gravock
gravityblock
Quote from: gravityblock on February 26, 2012, 01:21:11 PM
Gravock
God (the universe) is an isotropic line parallel to itself and vibrating on itself at right angles. He is like a system of axes in which the point of intersection of the lines is everywhere at the same time. Then He is many, because dimensions are contained within Him, when these are permutated, " n" equals infinity. Please remember that this is an attempt to explain, the unexplainable.
God, being an isotropic line, can be regarded as a system of axes, from which an infinite number of lines go out in all directions. As the centre of this axis is everywhere, we can regard the whole Universe as its centre. The fact that the lines of force are consequently unable to escape from the ubiquitous centre and are always encompassed by the Being of God, makes Him an Immanent figure. Thus, if the lines cannot move out from the Being of God, then they can only move within it. But as there is no such thing as interior or exterior, the whole Universe being a centre of lines of force, all the lines resulting from the isotropism of God will be found to be oscillating on one point.
We may therefore call the Universe a point of infinite oscillation. If this definition of the Universe is correct, God (the universe) is an oscillating charge superimposed on an infinite point, constantly causing a deformation of space, continually exerting its influence on the un-manifest, and automatically creating energy, and in consequence, matter.  There is only one Force in nature and this is the Electric Force.  Saying God is an oscillating charge superimposed on an infinite point is by no means any different than saying, "God is Omnipresent".  Omnipresent refers to God filling the universe in all its parts and is present everywhere at once.  If God did not exist, nothing whatsoever would exist.  God is fully aware of all things.  The universe can not be explained without God, thus the mechanical motion of the universe can never be understood if God is left out of the equation, which science has done.
This continual creation of energy in the Universe gives rise to an internal pressure in the nebulae which can be seen in the phenomenon known as "the flight of the nebulae."  As a result of this internal pressure they move away from one another.
You may raise the objection that this pressure is also applied in the direction of flight so that the internal pressure coupled with the external one would make them stable and they would not move apart, which would cause their mass to condense. My answer to this would be that energy created outside a galaxy tends to be drawn into the galaxy, condensing itself into material form. Thus we have an internal pressure coupled with an external decompression.
The flight of the nebulae prevents condensation taking place for three reasons: 1) This movement causes the interior pressure to disappear. However, nebulae appear to maintain an acceleration caused by an internal pressure within the Universe.  (2) As the nebulae move apart, that space which had been transformed into matter endeavors to return to its former state of primordial space in accordance with the law of rotation of masses in a magnetic field. This reconstitutes the energy that had been used for condensation of the matter, turning it into light, whose wave energy goes on decreasing until the moment of entropy is reached. This is what takes place on the Sun. Leaving aside the reaction that they bring about on the planets, the Sun's discharges into space are, in a sense, matter returning to its original state of primordial space.  Light from a myriad of suns in the various galaxies produces a very great force of repulsion on all the nebulae, and under this pressure they move away from one another.
In the first instance God supplied the power that brings about the deformation of space and the Sun, by an opposite process, turns it back into energy, thus re-establishing the balance. Everything comes from God and everything returns to Him. That is why neither matter nor energy exist, but only deformed space, which is called matter, and what we call energy is nothing more than a phenomenon of transition between primordial space and deformed space.
Gravock
Gwandau
Dave45,
This video has nothing to do with what Gravock is trying to convey.
Why on earth do you impose the old Christian guilt complex onto this thread???
Are you a troll?
Gwandau
gravityblock
Quote from: National Geographic News
Earth is wearing a thin antimatter belt, according to new data that revealed antiprotons trapped high above the planet.
National Geographic News - Antimatter Found Orbiting Earth.
According to Xydous, most of the anti-matter is either near the outer edges of the universe or at the center of the universe as a white-hole (anti-blackhole), while the rest of the anti-matter was captured by the aether.  If Stueckelberg and Feynman are correct in saying the electrons-positrons are the same particle undergoing time reversals, then both assumptions by Xydous will be correct.  Here's the basic idea.  Since we're moving in forward-time, then we'll see mostly matter at or around the center of a system, while the anti-matter is found orbiting the planets, orbiting the outer edges of the solar systems (such as the OORT Cloud), and then orbiting the outer edges of galaxies, etc.
If we were moving in reverse-time, then we would see mostly anti-matter near the center of the systems, while matter would be found on the outer edges of the systems.  In forward time, we would have black-holes at the center of the galaxies.  In reverse time, we would have white-holes at the center of the galaxies.  In summary, we could say both matter (particles) and anti-matter (anti-particles) are the same stuff.  If we could move in forward and reverse time simultaneously or not move in either time-flows (remain stationary in time) we would clearly see matter and anti-matter being the same stuff.  This means the electrons-positrons, the protons-antiprotons, the neutrons-antineutrons, the quarks-antiquarks, etc. are the same stuff.  If we were inside a black-hole moving in reverse- time, then we would be repelled from the black-hole at a tremendous velocity.  The black-hole will become a white-hole relative to us by a reversal in our time-flow.  Please note, reverse-time doesn't mean traveling into the past.  It's more like changing your frequency and/or polarity.
Quote from: Gwandau on February 24, 2012, 08:12:34 PM
It is exactly the way I have come to understand our center oriented truly relativistic universe.
Gwandau
Doesn't this post describe a truly centered oriented relativistic universe?
Gravock
