Why there is no measurable electric field in a magnet!
Started by gravityblock, February 24, 2012, 11:48:10 AM
gravityblock
Quote from: Gwandau on February 24, 2012, 08:12:34 PM
gravock,
It is a rare experience to hear someone explaining energy this way.
It is exactly the way I have come to understand our center oriented truly relativistic universe.
Although the words used differ from the words used by David Barclay in his book Unity, they hit the point just as well.
David, who is my mentor in true relativity, uses the concept Field Differential instead, but it covers just the same transition.
Gwandau
I agree.  Different terminology and language used, but the same concept.
Gravock
gravityblock
Both Stueckelberg and Feynman suggested that all electrons and positrons are the same particle undergoing time reversals.  The video on the dual charges (electrons-positrons) in action showing the 2 streams of current flow and the elegant explanation to why there is no measurable electric field in a magnet, should erase any doubts that the electron-positron are the same particle.  If this isn't enough, then here's a publication found in the General Science Journal titled, "Centrifugal Force in the Electric Circuit".  Below is a quote as found in this publication.  Please take note, this publication mentions how the electron-positron splits into two streams in a wire on page 5.  This is very similar to what you see in the video.
Current is the flow of negative charges (electrons) and positive charges (positrons) moving in opposite directions (time reversals).  One stream is running against the other stream.  The electron stream is the 'hot current' and the positron stream is the 'cold current'.  If you can accept the idea of the electron-positron being the same particle while these dual charges are moving in opposite directions or in time, then you must reject the idea of the electrons-positrons annihilating each other at any kinetic energy as it is being taught in Physics today, and seriously consider Xyodous's proposal that the electrons-positrons both need a minimal velocity of 0.62c before they have enough momentum to annihilate each other (that is one runaway sentence, lol).  The method I described in reply# 1 of this thread, is nothing more than a simple, but super efficient particle accelerator-collider producing excess heat along with a proton-antiproton to be used to create a very strong electric field which allows the process to become self-feeding and perpetual.
Gravock
Quote from: Frederick Tombe,
The electron-positron wind will split into two streams. One stream will flow under the wire and the other stream will flow over the wire.
Dave45
I proposed the same theory basically over on energetic, almost got branded, had to run for the hills  ;D
Dave45
For some reason I cant view the vid in your first post can u post it again please
dave
Dave45
Maybe this will help
This image is based on the model of a galaxy, its quite ironic that the only field we can see in space(the electric field) is the one we know so little about.
