quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 41 Guests are viewing this topic.
lumen
Quote from: sarkeizen on April 15, 2015, 10:23:31 PM
Riddle me this.  Your knowledge of information theory is somewhere between zero and negative a million right?  Why do you suppose that you can ask a question of relevance?
Here's a better link to Fu's (ancient) paper
Yawn.  It's no more a refutation of information theory than any of the bozos here selling experimental error.  Essentially Fu claims something happened which hasn't been replicated by anyone reputable.  It's recorded in a paper (and a video) which AFAIK has never been published in a Journal even by the comparatively lax standards in China.
Actually it has been replicated and is in fact known to operate as described.
AND.....
I was quite sure you couldn't answer that one simple question.
My book is now closed!
sarkeizen
Quote from: lumen on April 15, 2015, 11:51:38 PM
Perhaps "Known" in the delusional sense you use the term.  But is it "replicated by someone reputable" - in the sense that it was done in a highly controlled environment.  If so, where is the journal article of that?  Nowhere it seems.   From what I can see this is over ELEVEN years old and it's pretty much just sat there but I'm sure you have cooked up a conspiracy theory to help you sleep at night.
QuoteI was quite sure you couldn't answer that one simple question.
How do you know your question is simple?  Put another way: You're asking something like: "When is purple?"
I think you mean "mind". ;)
MarkE
Quote from: lumen on April 15, 2015, 09:48:16 PM
I have a question!
Now that there is a room temperature "Maxwell Demon", does that indicate that "Information Theory" is wrong or only some parts may be wrong?
Sarky? Your the expert.
http://www.mediafire.com/view/w3jvt0z3336f9h7/Maksvelov%20demon%20pobedjen.pdf
Just in case you don't know.
Capacitors store charge, just in case you didn't know.  Fu neglected to provide or use a discharge mechanism.  Such a shunt should have been engaged across the device output prior to any handling of the magnet and remained closed until the system was mechanically stable.
profitis
Sarkeizen:'To what you claim is an argument which is formal
AND compelling.  Right?'
Again you are requesting statement-status in a combat situation.you won't get it from me mr sarkeizen.you have to attack the scientific statement head-on using textbooks.
Sarkeizen:'Put together with another device to create a device
with more bits. :)'
Same as a computer yes.you have one switch that gives such n such amount bits now you can have two switches that give additional bits.by the way,a single two-bit can spontaneously grow into a larger magnitude two-bit yes.
profitis
Mark E:'Allegedly he did.  The device is not available for
independent evaluation.  Go put a AA alkaline cell in
the drawer and come back in 10 years.  It will still
have 80% of its charge capacity  without any claim of
a second law violation.'
Gold and platinum or nickel and carbon or any components from his patent are widely available for independant evaluation.any sealed karpen or karpen-related pile will lose exactly zero% capacity over ten years.infact they gain capacity after total discharge.very unlike a zinc-carbon.you can check all this out.
