Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
tim123
JLN's later work on this is interesting:
http://jnaudin.free.fr/rvproject/html/ugentest27.htm
I'm impressed with his building skills... Cool Single MOSFET amp... Still no actual OU though... I wonder if his design meets Mr Vialle's approval?
The thing with HF is capacitive coupling becomes really easy, and powerful.
I'd like to see JLN's Nextgen wire-core being placed inside an induction heater coil, with a ZVS driver - and see if it causes an increase in power draw proportional to the load...
Khwartz
Quote from: tim123 on January 24, 2014, 06:36:32 AM
Hi Khwartz,
  So the Pigtail is an autogenerator *and* it shows gravity effects too...
Can you give an outline of the most impressive results so far - i.e. what should an experimenter be aiming to replicate?
Is there a circuit diagram available for the reportedly OU version?
Hi again tim123 :)
I know near nothing about the "pigtail" and to be honest, I don't want to invest time in this device while it is not, this one, our "project 0" (the one everybody is invited to focus as the most promising for free energy production).
If you read my previous posts I think I have answered too to the question of "the most impressive results":
- COP up to infinite but mostly around 2.0 for basic experiment and 5 for more advanced one.
- Infinite charge of a pair of batteries in input AND with a load in output.
- Calculated potential for up to 6kW for a 1 m "barre" looks verified by the last 12 months of experiments where the equipments blows under the power (the "negative" one, to be exact, if I am not mistaking).
For the specifics for direct replication, I am waiting to obtain that the list I have made been fully checked by guys more familiar that me with the Richard's Autogenerator (which is indeed something else than the Pigtail, as I can know).
I will publish this list as soon as I can and then translate probably a whole existing replication if I can download the pics and schematics so I could upload them here.
Please just be patient cause it represents much data for me to get, condense, translate and publish, while somtimes I spend more of 1 hour to publish 1 post one my mobile :/ (20 min juste for this one! Lol)
Best regards.
Khwartz
Quote from: wings on January 24, 2014, 07:00:01 AM
some informations here
http://jnaudin.free.fr/rvproject/index.htm
http://www.magnetosynergie.com/forum/viewtopic.php?f=64&t=1475
This is indeed one of the replication I think about to publish here in english. But as is not the most recent one and nor the shortest!  :P Not sure it will be the first one, if I do.
Khwartz
Quote from: woopy on January 24, 2014, 08:50:39 AM
@Woppy
You had started to replicate in English, so I know you have some skills in English: wouldn't be a nice idea if you could complete the publication of your replication here? You have already all the materials for, I suppose, like pics and schematics ;)
Regards.
Hi Kwartz
Yes i did a replication of the Vialle U autogenerator. I include here a old video of my first attempt.
http://www.youtube.com/watch?v=mztzakUYoXw
My problem was that, at this time, i did not have a good enough signal generator to test different frequencies (around 3.6 MHz).
So i decided to replicate the Royer oscillator as per Jean Louis Naudin. And it work fine as per the first try.
But i realised very soon that the U gen is very sensitiv , and even a very small difference in the length of a wire could affect the results. And also probably each different copper tubing and the wrapping wire could need a different frequency and need a fine tuning at the input and output. So i got some crude results showing  me that the system is working as described.
The JLN Royer oscillator is a good demonstrator but  limited to the entry of  this fantastic  project. Than if you want to really go on,  you need  sofisticated material and knowledge and perseverance.
So i am now following the progress of the very good workers at Conspirovniscience, but i am no more directly activ in this field.
I am personnaly convinced that Richard Vialle is onto something , and i am happy that you try to enlarge the audience for this project. Bravo
Hope this help and good luck at all.
Laurent
Salut Laurent  :D
So nice to have you back on board on this thread! :) :) :) I was feeling a little alone ;)
Well, so very great too that you have summarised your experience with the Autogenerator, the U shape one. It describes very well imho the level where we are now and how much we need patient and skill experimenters to go further.
Woppy, could you help me in the different translations?
BTW, thanks for sharing your videos in English  8)
Just want to note for readers here that this experiment shows only the very basic principle: lighting a light bulb from the two halves of copper without connection with the inpout.
A second stage of experiment is to reduce the input power while been under load (while the light bulb is connected at the output of the halves).
Then, the third stage it is to obtain overunity of the specific ratio: output power of the load under the input power of the input of the coil wrapped around the halves.
The fourth is to get the "avalanche" effect, a huge pic of power in the system (and try to not blow everything!   ;) ) and to obtain the second and general overunity COP: outpower of the load under the consumption of the whole powersupply system and frequency generation and control; while this ratio can be NEGATIVE! means THERE IS NO CONSUMPTION, BUT PRODUCTION OF ENERGY FEEDING BACK THE SOURCE ITSELF.
The fifth is to use this power to feed back an "input" pair of batteries (alternatively feed) while still have the two halves on load.
Each of these 5 stages have been successfully realised, even if the fifth one needs to be made at will and with full control out of labotatory, on which guys are already working here but do need help!  :-\
The six, would be I think to stabilize everything and reach great useful power to feed a home.
Did I missed something, dear Woppy?  :P
Otherwise I have still too this long list of specifications here:
http://www.conspirovniscience.com/forum/index.php?showtopic=1504
Time: " Lundi 20 Janvier 2014 à 15h35".
Could you check it yourself and/or invite others of Conspirovniscience.com to do the same, so that I could post it here translated when fully checked? As you may feel, there some nice insistence here for real objective stuff for replication  8)
Bien amicalement, Didier.
Khwartz
Quote from: tim123 on January 24, 2014, 12:40:29 PM
Theory of the Autogenerator...
This page on JLN's website summarises Vialle's theory of the U-autogen, and it's ok in Chrome translate:
http://jnaudin.free.fr/rvproject/html/principervgen.htm
:) Yes, indeed! And you have very well chosen "the core" ... of his theory regards to his Autogenerator  :D and I confirm the translation too :) (thanks for economising my time  :P).
