0 Members and 28 Guests are viewing this topic.
NRamaswami
Great Work Dieter. The simpler it is Better it is. I have only plastic tubes and soft iron rods and lot of coils and I will check if what you have done here could be replicated on a larger size. The cores though will be straight NS-NS-NS only. Let me check and tell you if it works. But since we things a lot bigger, it will take some time for us to do.
MenofFather
Quote from: dieter on March 22, 2014, 10:12:35 PM
It is incredibly simple, but here you go. The resistance in AC is complex, so the primary does not simply run on 0.75v at 200 mA, but in fact on 0.188 v at 114 mA.
Can you draw, there you put voltmeter and ampermeter in input coil?
Good work, keep going...
energia9
dont forget, ac is not dc, so calculation differs too,  this is not overunity .
MenofFather
Quote from: energia9 on March 23, 2014, 05:51:18 AM
If he meashure in AC mode with multimeter, then measurements can be correct.
hanon
Dieter,
Great results!!! I suppose that if you are also applying Jensen UDT then you should have used an air gap in one side of the central leg to increase its reluctance. Have you done so?
You device recalls me to the Thane Heins transformer.
Keep on the good work.
The F-machine is similar to the Jensen UDT:
http://alexfrolov.narod.ru/ph-machine.htm
http://en.shram.kiev.ua/top/invention/invention2/2.shtml
http://www.free-energy-info.co.uk/Issue5.pdf        See Page 6
