0 Members and 69 Guests are viewing this topic.
MenofFather
https://www.youtube.com/watch?v=HH8VvFeu2lQ
Here also one output coil shorted. (it Ф transformer) Efficienty of it about 190 precents, but or there some errors or not wery simple it make, because I not get that results like this gay in this video (but I not 100 precents exatly make like he, I use different cores, other wire and so on).
Doug1
"My request is what are the precise equipment that should be used to measure the output and do I need to maintain the same resisitive load to calculate. That is not known to me. I would be greatful and obliged if you can guide how to measure and maintain the log for AC currents."
Yes use the same load to test but without the right equipment I dont know how to rig up a substitute to measure the watts accurately. I dont even know what your service is from the grid, single or three phase.I guess your on 220 or 230vac from what you have said so far. There can be too many variables to just guess at the condition of distribution system or how your shop is wired or how the rest of the consumers on your line have split their loads. A system out of balance will have a lot of problems during peak demand periods.Maybe you should try to test at a time of the day when fewer people are drawing more form the system. Still not sure what your output goal is. I stated mine a long time ago in horse power and kw so I would know how much material would be required or at least have something to work off of or toward.
Cadman
Only 21 days until the 100th anniversary of the Buforn patent 57955
14 de Abril de 1914
Shokac
dieter
MenofFather,
first of all, say Guy, not gay.  Having all those Anodes and Cathodes is already enough.  ;D
So did you build a device, do you have details, pictures?
One thing I noticed yesterday, when the core contact (example given: between E and I) is not perfect then the efficiency sinks rapidly. So therefor I do now use a vise ("schraubzwinge"), with two wooden spacers to prevent altering the core flux.
Update of my tests: 3.6 Ohm shortened (as mentioned) didn't perform well eighter, 20 mA with open and 40 mA with closed "lenz compensator" coil (love that name), so here it really is half the flux. Tested the initial duo again, now 53 mA.
What makes it so difficult to measure AC in is, in a Transformer the amps and volts are out of phase 90° as long as there is no load, and therefor the power factor is zero. You may have amps and volts and yet the consumption may be zero.  And the whole goal here is to draw from the output without to change that zero power factor. Normally in a transformer, the 90° phase shift will decrease, the more you draw. At full load the amp wave and volt wave are matching, phase shift is 0°, power factor is 1, consumption is really equal v*a (*0.707, cause it's AC).
An oscilliscope would be helpful. Isn't there any dead simple 99% software oscilloscope one could build with a couple of resistors?
Hanon, yes, I' ll put all results in one thread and or pdf the sooner or later. With respect to Clemente Figuera I will now back off a little bit in this thread.
