digitalindustry
Quote from: marathonman on December 21, 2015, 12:28:57 PM
digitalindustry,antijon ;
Quote "all of these devices are always about a 'rotating magnetic field'
every-time there is inertia there is 'energy'  because gravity is 'magnetic at frequency"
it's about time This is the most intelligent sentence you've posted yet.
  that so called fairy wispering in me ear has a 5 kw system working for over a year now.
as he mints to me i post to the forum but whether you heed the information is entirely up to you. that is why my design took such a radical turn in the last few months was from his operational hints. why he gave to me i don't know, can't answer that.
sure i am an ass hole, you are not telling me something i all ready know but i do enjoy helping other that are willing to help them selves and not blindly jump in a pit because of a shinny object.   i just think that the  areas your engaged in are secondary to the main real concern, the pulsing, operation and dimensions of the cores. without these main concerns you will never have a working device.
i know this device was using DC at the time in question because the Canary Island had no AC at the time of his builds and he used a DC motor for his commutator rotation. this is not to say that AC can be used as i so recently found out but the control system to manipulate it will be to very elaborate as compared to DC.
he used DC through a resistor network to split the currant between two opposing Electromagnets (same polarity) as not to interfere with each other but help amplify the incoming signal (push pull/push push) while rotating the commutator to raise and lower the currant in the electromagnets in opposite fashion.
that is as plain and simple as i can put it so if it is not understood the exchange of knowledge has ceased and one's intelligence level will remain stagnant.
i'm fine with all that as stated i recommend people build the 'resistor' to the original patent  (or a variation of that)
to tell you the truth after 100 + years (of human history) there are so many devices that could be built this would be a fun one to make.
you are not currently registering even close to 'arsehole' on my meter, i wouldn't even say you are annoying.
hanon
QUOTE FROM FIGUERA PATENT 30378 (year 1902)
In Gramme ring and in the current dynamos,
current is produced by induction exerted on the wire of the induced circuits as
its coils cut the lines of force created by the excitatory electromagnets, this is,
as the induced circuit moves, quickly, inside the magnetic atmosphere which
exists between the pole faces of the excitatory electromagnets and the soft iron
core of the induced. In order to produce this movement, mechanical force need
to be employed in large quantity, because it is necessary to overcome the
magnetic attraction between the core and the excitatory electromagnets,
attraction which opposes the motion, so the current dynamos are true machines
for transforming mechanical work into electricity.
The undersigned, believe that it is exactly the same that the coils in the induced cut
the lines of force, or that these lines of force cross the induced wire, because
not changing, by rotation, the arrangement of the magnetic fields, there is no
necessity to move the core to create induction.
hanon
http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg420569/#msg420569
Maybe also Figuera used a notation trick in his 1902 patent. In spanish the possesive pronoum "sus" is not different to denote the kind of owner, as happens in english. "sus" can be translated, with no difference, as any kind of 3rd person, singular or plural :  "its", "his", her" and "their".
ORIGINAL PATENT TEXT:
"Varios electroimanes están colocados uno enfrente al otro, y
separados sus caras polares de nombre contrario por una pequeña distancia."
ONE POSSIBLE TRANSLATION:
"Several electromagnets are placed one in front of another, and
separated their polar faces of contrary name by a small distance."
OTHER POSSIBLE TRANSLATION:
separated its polar faces of contrary name by a small distance."
If the real meaning was "its polar faces" then Figuera was talking about the two poles of the same electromanet, not the poles of two different electromagnets.
Again, we find a polemic way to define the real polarity of the system. Was it the Columbus Eggs mentioned by Figuera?
hanon
marathonman
Repost.....foul
I like that last post Hanon. was it a moment of silence for Figueras. ha, ha
Quote; "contrary name by a small distance."     meaning "opposing or against"  opposite poles with gap used to tune the primaries to the secondaries.
now this pic below will get a laugh.
