0 Members and 24 Guests are viewing this topic.
NRamaswami
Hello All:
Can some one explain to me how to calculate and find out the capacitance of a coil..How do we know what much of current can be retained in a capacitor or coil..Is there any formula for it? Please oblige.
dieter
Ok, everybody,
I want you to try, just for a moment, to think out of the box. I know you are openminded, otherwise you would not believe in Free Energy.
So what I got is success, but I had to stretch the term "Figuera" pretty much. Nonetheless, save the image and revisit it later, just don't ignore it please, cause from my POV this is the real deal and it means something to me that I present this here and not on youtube.
As so often in Life, I discovered a feature by accident. And this feature is yet to be exploited,  as right now certain ratios are coincedental. Ok, in simple terms...
I connected the middle coil to the 2 halfwave pulses, virtually reunited them to AC. So this was now the primary. Then I connected a rectifier, a LED and the voltmeter to the right coil.
I measured 2.18 vdc at 8.3 mA, the LED was dimmly lit.
Then out of boredom I short circuited the left coil, and beng! 2.67 vdc at 49.3 mA !!!
The Led was blindingly bright and the device became more silent.
Now, by mistake the left and right coil are not identical, the right one has more turns and 7.4 Ohm, compared to 6.4 Ohm that the left one has. So I made a test, swapped them : left out and right short circuited. Interesting result, efficiency dropped to
2.36vdc at 39mA. So the efficiency is higher when the shortened has fewer turns than the output coil (which is yet to be exploited in further optimizing).
Anyway, long story short: I did this measurement with greatest care and honesty and I measured all with the same meter, which appeared to work properly:
In: 0.021 Watt
Out: 0.131 Watt
Efficiency: 614%
I calculated roughly, a device of the size 1.5*1.5*0.9 meter would produce  3500 Watt, at 500 Watt Input. However, I run the test with a very small current, although the ferrite core seems to be saturated quickly in this mode.
Ok, here's the pic:
a.king21
Quote from: dieter on March 22, 2014, 07:14:43 PM
Ok, everybody,
In: 0.021 Watt
Out: 0.131 Watt
Efficiency: 614%
Ok, here's the pic:
Dieter, I really need a circuit diagram to properly understand what you mean.
Is there any chance you can make  a circuit diagram please?
Great work by the way.
dieter
It is incredibly simple, but here you go. The resistance in AC is complex, so the primary does not simply run on 0.75v at 200 mA, but in fact on 0.188 v at 114 mA.
