0 Members and 54 Guests are viewing this topic.
IMIGHTKNOW
Quote from: floodrod on April 04, 2023, 02:58:59 PM
Personally, I don't even want to experiment with extracting power from coils until I perfect the sine wave.  The idea is to create two near perfect sine waves that bottom out on the zero line. So basically we are simulating two sine waves with a positive bias.
And as I said earlier, we can actually do this without switching direction of current going into the coils. If you start drawing it out and thinking how back EMF and induction work, you may see the advantage that I'm seeing.
The magic occurs from the decreasing current. Or when the sine wave is going down. And every time one side is going up, the other side is going down.
PS There is no BEMF in this device or induction is lost I hope you realize this.
If you have the wave form bottom out on the zero line as you just said induction will cease and all compression between the opposing electromagnets will drop. According to Doug1 and MM this is not the correct thing to do nor does the patent say zero. Reason be is the primary electromagnets are reduced to just get the sweeping action, no more no less.
Doug1 quietly built this device right under everyone's nose because they were just to busy scrambling to realize it. Doug1 mapped out a plan, gathered all associated information then executed his plan.
All I see here is building to unknown specs.
The one thing I know for sure you got right is the Figuera device generates on the reducing electromagnets so soft coupling doesn't matter to the device or lenz law. One is pushing the other is pulling which does the generating while both electric fields are lines up with this special switching. Being opposing means the Lenz law is not an issue like in a standard rotating generator with magnetic drag as Doug1 and MM had said.  My ex MIT neighbor is having a field day with this patent grinning from ear to ear.
Good Day!  ;D
phoneboy
@ IMIGHTKNOW
"All I see here is building to unknown specs."
Not for nothing, but what "SPECS" are you referring to?
Other than the description of operation by the author (which is vague in parts),the only clearly defined item in this devices patent is the brush wheel.  The other part of the diagram is a crappy electrical diagram.
You keep sprouting off like you know the exact SPECS or contruction methods of Figuera. Wouldn't have an issue w that except  you'd  have to be over 100 YEARS OLD and have spoken to him personally.  The only other rational explanation would be that you are the kid from that Bruce Willis movie "The sixth sense" all grown up, and have been having fireside chats discussing this device w the spirit of Figuera.
If the latter is the case, then why did u call yourself "IMIGHTKNOW" marathonman, when you should have clearly called yourself "ISEEDEADPEOPLE" ??
forest
Go to Las Palmas of Great Canaria and find Figuera device photos in museum that would be more productive then bla bla talk here
phoneboy
Quote from: forest on April 05, 2023, 03:14:19 PM
You're correct about the blah blah
I've attached a couple of animated gifs of field simualtions, and a rendered layout from a part of a CAD model I worked up on this device.
This is all armchair but maybe it'll help someone building.This design should induce as the inducers don't share a common core.
The gradient arrows denote the induced current direction from start to low/peak current.The Logos on the inducer cores (all ferrites) just indicate whether they are low starting or high starting current.
This configuration would put out AC as its destructive interference.
Speculative: What's more interesting to try would be to flip one of the inducer cores so that they match the patent orientation of N S as that would be constructive interference and possibly put out DC?
IMIGHTKNOW
Sorry It doesn't bother me that your gay. ;D I just don't care and the fact that MM does have his own site not me . We have a full lab and I am thankful for that. Good things on the horizon.
Specs like what loads are you building to as in just like a standard generator. You do know to build a gen you do have to have a load in mind.
Then you have to figure our how many secondaries you are willing to deal with or are willing to split the load to. Then your primaries have to be built on that assumption being split each being accountable for 1/2 the secondary load. Since resistance is detrimental to all devices It is likely they need to be wound specifically as electromagnets to react to specific current changes immediately. One long winding will not do, to much self inductance, capacitance and resistance. But I imagine your actually smart enough for all that.
Another thing the inductive resistance has to take the reducing electromagnet just far enough to get the sweeping action across the secondary then back to full potential as the other is reduced otherwise induction will fall. But again I am sure you knew that Right !  ::)
Not to mention a slew of other things you probably didn't account for or surely didn't think of.  ;D
But then to think of it your lovely ability to work with others just might get you there, Doubt it!
What you could start out by doing is apologize for being a dick and learn how to work and talk to people. Your chances might be a little more successful. ;D but then again I am on the worst rated forum Doh figure!
We will see if you can piece the puzzle together without the aid of popups like the rest!
Have a wonderful day there fella!
PS, Lovely sim, to bad your cores are wrong!
