Naphtalen in your gas tank ? 30 % more mileage ?
Started by hartiberlin, July 29, 2006, 04:16:12 PM
aarnold
Hi friends,
today I put gas in my car... after testing the 15 mouthballs of Naphtalen nothing changed... maybe the motor is just a little bit quiet, but just this. The performance is the same. I'm going to try more naphtalen ( I put 1 mouthball for each 4 liters), and maybe I'll try another mouthballs, maybe this one that I tried are not olny Naphtalen.
thanks
Augusto
Quote from: aarnold on August 03, 2006, 01:25:04 PM
Hi friends,
today I bought some naphtalen. I put gas on my car (renault megane 99). Bought some gas in a bootle too do dissolve the naphtalen. My car made in this last time 440.8 kilometers with 51,06 liters of gasoline (8,63 km/l). I put 15 mouthballs in 1 liter and I'm waiting to dissolve. I'll make this test and a week by now I'll refuel my car and see the results to post in the forum.
My friend that is a mecanic told me that the naphtalen creates a type of "gel" that can obstructs the injector peak. So I'll try to tell you the results..
thanks
Augusto
Walter Hofmann
Quote from: aarnold on August 15, 2006, 10:11:52 AM
Hi friends,
thanks
Augusto
Hi friends,
thanks
Augusto
Hi augusto
I believe you are putting to many of the naphthalene pills in. I used the first time 10 pills of 20 gallon what was about 1 pill for every 8 liter, now I only use 5 pills for 20 gallon and there is nothing different from the engine working, still the same bit higher idelle, and quieter run, after the first 100 miles my tank gauge shows about 2 gallon used plus minus because I dont know how exact this gauge is in such low usage.
walt
pese
Walter Hofmann
Hi all,
here are the results from the second run with naphthalene moth balls.
I did the second run with only 5 pills of the naphthalene moth balls for 20 gallon and it did give me 400 miles and this just city traffic this is about 80% more milage against with regular gasoline which did give ma only 230 miles for 20 galon in my 1997 safari van 6 cyl 4.3 liter with 168.000 miles on it allready.
This conclude's my test and I will use only 5pilles on 20 gallone in the future.
It is worth a try!
greetings
walt
mark australia
Hi Walt
this sure beats paying $1 to $2 per pill for the other fuel savers.
Mark
