Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
plengo
Many has been asking me what is that I have done with the cells on the series of videos called "Thermo Static Crystal cell".
It is very simple. The physical construction is pretty obvious on the videos. The "forming" of the cells is also simple.
Copper is the positive and Magnesium is the negative. I apply a 60 volts at 2amps (max) to the cell until it get so hot and dries all the liquid. I apply negative to the Copper and positive to the Magnesium. Some sparks sometimes happens but no problems so far.
I do this only once until the cell is completely dry. There will be lots of vapors so do it on a ventilated area. After that apply some Epson salts solution (usually 2 tbs to 50 ml of water).
Once you do this, the cell will have an amazing performance.
Fausto.
ibpointless2
A update on my 5 foot crystal cell long term test....
The cell still producing power and still powering a LCD clock. I dissected the cell too and found some corrosion but not as much as i thought. The cell never needs water and been running the clock since 2011. I installed a window on the cell so i can see corrosion without taking the cell apart. The Magnesium is still strong and not brittle and the cell was giving me 1.411 V @ 100uA when I had it disconnected from the clock. Power came back instantly when shorted and when first hooking it up to the amp meter it started at 80uA and climbed to 100uA. It looks like it will run for a long time.
YouTube video...... http://youtu.be/0RaIbf8wyPY
plengo
Today I learned something interesting about the crystal cells i am doing. I made this mix that dries up very very fast and becomes very dry and hard very fast.
If you add water, a tiny little bit, the mixture becomes very soft, wet and mushy. A few seconds/minutes later it dries up very fast and again the same thing.
While the mix changes back and fourth, lots of energy comes out as electricity, a ratio of 1 or 2 ma per square inch in size (square).
The time that any reaction happens in the Magnesium it is very diminished because the counter effect of the mix concerning the metal, the mix sucks the water up and the Magnesium has much less time influenced by the presence of water while "ions flows" in one direction more than the other. The flow of the water being absorbed makes the travel of the opposite ions to flow, as an exchange in energy stored in the metals, slower than the other "ions" or "cation" (whichever satisfies your view).
This is in effect reducing the level of corrosion by orders of magnitude for much more energy out ration to the size of the cell.
If you have a pile of the mix dry, very dry, you don't need water, you can just poke the rock slowly until it becomes watery, softer and very soon mushy and obviously wet but no water to be found anywhere when it was very very dry like a rock.
This mix has an amazing capacity of storing water and releasing too.
This combined with a good "polarizer" in the mix, a lot less gas is released and any that is released becomes trapped in the structure full of empty spaces (crystal structure with columns, spaces, more columns - resulting in more space than matter) of the mix, specially when semi-dry, where it becomes very spongy and resilient, very bonding like tick glue.
This allows the mix inflate like balloons until or either burst (usually the biggest ones outside the edges of the cell structure) or gets absorbed again. Inside they must be containing the gas by cheer pressure and become absorbed into the mix again. An infinite cycle the mix is capable.
This and the relationship with electricity it is another unimaginable thing. All I can present is the data I collect and my conclusions based on the data.
My old cells with this mix, do produce much more energy for much more time with a good ratio of power out/mass of metals/mix.
I have to organize my notes and post them here with pictures and hopefully with videos too.
Fausto.
Allwest
Fausto,
Thanks for the video post
