Friction heater running in my house
Started by oilpiggy, October 31, 2012, 02:25:24 PM
JouleSeeker
Quote from: JouleSeeker on December 19, 2012, 09:30:20 AM
I also find Gabriel's work to be very impressive, and encouraging!
His device is amenable to careful scientific testing.
1.  First I would start with running the hot-cylinder alone in a water calorimeter, which I have built and calibrated in my home laboratory. I have used this calorimeter (and variations of it) in energy studies many times (see, for example, http://pesn.com/2012/11/19/9602225_Steven_Jones_replica--Pons_and_Fleischmann_XS_Heat_not_from_fusion/
2.  Careful measurements of the input power  (I have several types of meters for measuring input power if AC, and others for measuring input power for DC) and the output power (heating of a known quantity of water).  Among other power meters, I have a standard electric-power meter as used for homes on the grid.
3.  It would be very important to run CONTROLS, such as immersion heaters in water, to compare with the heat-output of Gabriel's device.
4.  For instance, one could use 500 watt-hours put into a simple immersion heater and measure the temperature-rise, and make sure the calorimeter is properly functioning and calibrated.  Then the SAME amount  (e.g. 500 watter-hours) would be fed to the motor on your device and the temperature-rise in the calorimeter from the hot-cylinder measured.  From this one can calculate the efficiency of the immersion heater = control (which should be close to 100%) and the efficiency of your device (presumably over 100% compared with input electrical energy; like a "heat pump" perhaps).  In "cold fusion" circles, this is simply called "anomalous excess heat" -- since the origin of the anomalous heat is currently unknown.
The measurement is conservative in that the heat in the motor is not measured for this straightforward first testing (heat from the motor could be measured later).
5.  Several tests would be done, varying the amount of water bath in the calorimeter, temperature probes used, etc.
6.  Later, if Gabriel agrees, I could arrange for use of a more sophisticated calorimeter.  But - I would not do this at first.  The above calorimetric tests can be done quickly and in a definitive way in my laboratory, as long as the anomalous xs heat is more than about 20% of the input electrical power.  I have already built and tested the needed equipment.
7.  AFTER these initial "anomalous heat" tests, I propose to test the device for safety by looking for any potentially dangerous emissions coming from the device -- looking for X-rays, gammas, betas, alphas, neutrons and RF radiation.  The device can be shielded to prevent harm, but it is crucial  IMO to make sure that the device is safe, for example for home use.  It is conceivable, although not likely IMO, that the anomalous heat is nuclear in origin (LENR), and if so the device may need to be shielded.
...(my web-site page:  http://www.physics.byu.edu/research/energy/ )
   Thanks Chet, and note @all that I had a communication from Gabriel that he accepts the above testing (there may be few variations).  I find so far that Gabriel is honest and willing to have his device tested rigorously.  The testing will likely take some time due to holiday travel and the time required for careful testing and evaluations.  Good science takes time.
Doug1
Bruce
"There is no need to play the bad censor cop, it's simply stifling discussion."
To all :Not my intent to play cop of any sort. I thought I raised enough questions regarding the home's construction and more.
   If I wanted to play cop I would have asked for proof of the savings on his electric bill first .Two to three yr history of uttilty bills durring the winter.
    Regardless of any results from anyone unless they can prove they have tried everything possible then it is still in the "maybe" column.
   I would also like to know what viscosity oil he used maybe even the type of oil. The friction will change with temperature of the oil ,dropping the load on the motor as the oil heats up. An oil that starts out too thin will take longer to warm up from friction.
Bruce_TPU
Quote from: Doug1 on December 22, 2012, 11:23:51 PM
Bruce
Huh??  Not "playing" any sort of "cop".  Simply answering MH post to me earlier.
I have already said that I find this heater "interesting", and actually took some time to research it, the history of friction heaters in the FE community, and spoke with Gabriel via email.  It is a detailed build with precise measurments.   I also found the idea of combining several ideas within the friction heater, "intriguing".  I actually like to build things, not just talk about them.  So my own version of a friction heater might make for a fun project.   ;) :)
Using the following idea, combined with nanoparticles mixed with the oil, to heat the oil and use as a heater (not as a water heater).  Same idea of friction heating the water.  This seems a bit more efficient at first glance to me.
http://www.youtube.com/watch?v=yh_-DUKQ4Uw
Cheers,
Bruce
oilpiggy
hello everyone,
I don't have much to say after reading the posts from MH.
I feel that I have been forthcoming with all my plans of this build. I some can not replicatethis build after everything I have posted,... I am at a loss... Look I have clearly stated that I am on the cost with my family and will not be spending any of my time with this heater or this forum untill I get back home.
As far as the 50$ for a cad drawing of this heater, I THINK that is a fair price.
I will not spoon feed people like you MH or entertain you by answer question that have already been answered.
Thank you everyone who is supporting this build. Together we can make a difference.
Back to my vacation and my wife and kids.
Thank you
Gabriel
JouleSeeker
Hope you have a wonderful vacation, Gabriel, and merry Christmas everyone!
I wouldn't worry too much about MH or those who mock.  Agapae love, said Paul, "vaunteth not itself, is not puffed up". 1 Corinthians 13
And a Happy New Year!
