Donald Smith Device self looping no cap no batteries bright Lights !
Started by gadgetmall, November 09, 2012, 06:22:34 PM
Bruce_TPU
Quote from: mrclean on November 11, 2012, 02:09:00 AM
hi everyone, i am not using any tricks, but im having a hard time reproducing this myself, so i hope not to cause too much frustration, but here is how i have it wired...
http://img802.imageshack.us/img802/1874/imagedmb.jpg
correct that it needs the 9v in FG, or nothing is telling the transistor to do anything. and freq being critical here i believe.
but the signal gen cannot run the system alone with out a battery pulse.
like i said tho, if it wont work dont spend to much time on it.
however the Bitoroid i feel is very much the right direction
Interesting set up.  From the video I suspected the negative only was connected to the other battery.  And posted such.
http://www.overunity.com/12716/probality-of-god/msg343603/#msg343603
Hi MrClean,
In your circuit, you have the word "theoretical self loop",  is this because you are not yet convinced it is so?
Very good work so far.  But figuring out why it is working and being able to replicate it is every bit as important as having it work, in my humble opinion.  So please keep at it!   ;)
Cheers,
Bruce
poynt99
Kurt.
Your big 1F capacitor is connected according to your diagram. Aren't you saying in the video that it is disconnected?
Also, what is the source for the 9V which is supplying the driver circuit? You didn't show this in your diagram.
ETA: What is that "parallel free wire" used for?
ETA2: Further annotated the diagram.
poynt99
The way I see it, Kurt's 9V source is either a 9V battery, or he is regulating the 12V input from the 12V battery/1F capacitor down to 9V.
By "isolated" I suspect he means that the 9V supply is not connected to the transistor collectors.
Of course it won't work without the 9v supply to the oscillator portion. But.... will it work without the One Farad, 12 volt capacitor?
mrclean
Quote from: poynt99 on November 11, 2012, 12:47:15 PM
correct, the 9v does not run collectors, but despite the interesting results, im concluding the results to be an anomaly, i cant guarantee that everyone will see these results, and im not able to reproduce it all the time
