Keppe is headed to the big show, First exotic product to market
Started by ramset, September 10, 2013, 08:40:14 AM
tinman
What i need is the fan modle they used,so as i can get the right blade they used.Even better would be one of there kit's,but that isnt going to happen any time soon.
So any one that has any info on the standard fan they used in there comparison video,would be of great help.Also there latest test videos would be good to.
http://www.keppemotor.com/pt/informacoes-tecnicas.php
They do not give more detailed information !
It will be easier to ask them directly about the wished technical details !
Sincerely
              CdL
p.s.I: #23/24: they only calculated with 10% inverter losses for the conventional fan
p.s.II :Farmhand,reading your Energeticforum-keppemotor-input (05-02-2013)
here my "resonant charging circuit" response,also for pulse motors
[size=78%]http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100114&CC=WO&NR=2010003394A2&KC=A2[/size]
ramset
Sir thank you for the info ,and yes I will be calling their "Factory" in the next few days..
Chet
Thanks Grandma
Farmhand
Quote from: lancaIV on September 12, 2013, 11:32:58 AM
Sincerely
              CdL
My motor doesn't use capacitive windings it uses capacitors and normal coils. No bifilarly wound coils in my setup just regular windings in parallel for less resistance considering the wire I used, the capacitance secured in a bifilar coil would be nowhere near the 330 uF my charging coils discharge into. My motor is still in development, i just don't have the time to work on it I am too ill and too busy. I have serious health issues. Debilitating health issues. I get sine waves on the capacitors the charging coils dump into and the charging coils help drive the rotor. The capacitance is separate from the coils. I am using two 330 uF caps one for each motor coil and a dual parallel winding charging coil
I would like to see someone create 660 uF capacitance in a bifilarly wound coil.
Anyway the description tells of a coil itself with an inductive reactance of zero. Mine does not, it does has inductive reactance. It needs the reactance and delay to create the second delayed driving phase I've never seen that patent before and I don't believe it describes my concept. My motor makes two offset phases of driving forces on the rotor the power is delivered to the rotor in two separate phases from one input pulse.
QuoteThe invention relates to a capacitive winding which is made of copper wire, has an inductive reactance of zero, is composed of two parallel conductors (1, 2),
And before anyone says, yes the current does stop in both coils when the motor is operated in its optimum "window". however it can be pushed past that by increasing the voltage.
I did make a mistake in the regular version with no charging coil as the inductor between the return cap and the supply cap will not allow the charging then dumping of the return cap, however that is easily rectified by using more inductance in that extra inductor or a switch if not using a charging circuit, if using the charging circuit that inductor is unnecessary. You must remember I am and was working while on heavy medications for my debilitating illness and was pushing the limits of my physical and mental endurance. But I did produce a working prototype even though it is not ideal by a long way it is the concept I wanted to get out there. Someone will probably patent it, Not my fault I shared. Next time I have an idea I might just keep it to myself considering the amount of wasted effort I outlaid to try to convey my intentions. The second driving phase in my setup has similar drive to the actual drive coils. The charging coils are not capacitor coils.
Cheers
@Farmhand: I did not write that anybody has "occupied/plagiated" your idea I showed you only a feedback circuit wich uses your so called "resonant charging"!
The slowakian inventor Pavel Imris works since several decades in this technical area !
This "windings with capacitors=capacitive windings ;) "-concept has been adapted to several conventional motors but the technicians has not been good enough to reach the theoretical-mathematical efficiency point  ???
"You must remember .." this point let me remembering about the JackH-story several years before.
I did not know before your last post about your personal health issues !
Sincerely
            CdL
