Keppe is headed to the big show, First exotic product to market
Started by ramset, September 10, 2013, 08:40:14 AM
ramset
@All
I spoke with a representative from KEPPE today,very helpful and informative person.
There will be some back and forth arrangements made for a test of the
Keppe Motor technology.
Will keep you posted.
Thx
Chet
Thanks Grandma
tinman
@Chet
I just need one of there fan blades-nothing more,other that there claimed RPM per watt.
tinman
Well now we have some numbers to work with.
The Chinese company tested the Keppe motor ceiling fan compared to the most efficient conventional ceiling fans of this kind presently on the market (as far as they are aware), and found that it is up to 4 times more efficient, consuming only 10 Watts at 250 RPM.
So 250RPM/10watts= 25 RPM per watt.
Now keeping in mind that this is with there new-more efficient fan blade design. So no indication as to how it would perform with a standard blade,as is fitted to other ! off the shelf ! fans they are comparing there unit to.
It also seems keppe has found a new energy source Essential Energy
Quote: According to Keppe, the process is actually the opposite, meaning that matter comes from a previous, primary energy called Essential Energy
Farmhand
Quote from: lancaIV on September 13, 2013, 05:03:23 AM
@Farmhand: I did not write that anybody has "occupied/plagiated" your idea I showed you only a feedback circuit wich uses your so called "resonant charging"!
The slowakian inventor Pavel Imris works since several decades in this technical area !
This "windings with capacitors=capacitive windings ;) "-concept has been adapted to several conventional motors but the technicians has not been good enough to reach the theoretical-mathematical efficiency point  ???
"You must remember .." this point let me remembering about the JackH-story several years before.
I did not know before your last post about your personal health issues !
Sincerely
            CdL
No probs lancaIV, I didn't take it that way, the patent document predates my efforts anyway, the resonant charging circuit itself was not the point of the motor circuit.
The point of the motor circuit is to get the benefit of the second phase from one pulse input and to recycle the energy from the magnetic field collapse without tying the mosfet drain to the supply rail directly as well but without a battery. The resonant charging circuit allows that to happen, the increased voltage into the cap to discharge through the motor coil is a benefit as well. If the charging coils inductance was cancelled fully then the charging coils would be in phase and basically just in series with the motor coils.
Mine are lagging in phase to the motor coil and so produce a second driving phase when the charging coil is placed placed at the rotor in the correct position to drive it. Because of the lagging phase of the charging coils the discharge from the motor coils field collapse goes through the charging coils in that phase and is recycled that way.
About the health issues I was just kinda taking the opportunity to explain myself. When I am layed up all I can do is think. But to put thoughts into a device takes effort and time.
If I am to do things I must struggle, is all. It's much more difficult for me to do things and concentrate while on heavy pain killers and still in much pain. I am happy to say I think I
found out what ails me and I am improving rapidly. I hope to contribute a lot more in future.
Oh and it's not my resonant charging circuit it is the brain child of Tesla in the patent "Electrical Igniter for Gas Engines". http://www.google.com/patents/US609250
You can see in the schematic the delay in the phase of the currents in the charging coils. I demonstrated it as well. The amount of phase lag in the charging coil can be altered.
Regardless I am off topic. All I will say further is the circuit has more potential than I was able to show.  :)
Cheers
Farmhand
Quote from: tinman on September 13, 2013, 10:36:51 PM
A fan should be rated on air moved per Watt. RPM with a special blade it's almost meaningless to measure RPM per Watt. I can take the pitch off a fan blade and make it spin really fast and push less air but that is not an efficiency improvement. Tinman you need an actual one of their blades. I know you already know this, just repeating what you said.
We have always known that all matter comes from primal energy that is not new. Mass is formed by the contraction of the electric poles according to Walter Russell. I think matter is similarly formed from primal energy.
Some think Walter received enlightenment through spending much time on his own.
Does the keppe fan deliver more work output than is done to run it ? That is the question.
