Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
This topic is inscrutable. It might be wise to try and understand what Jerry try's to make of it. From the outset:
"A double magnet system cannot have the same energy in opposite sides if one side is the mirrorimage of the other. That is, there is a quantum state of the field that will not allow for equal energies in the opposite and mirror image field".
synchro1
Take a look at this video on the scalar Faraday:
http://www.youtube.com/watch?v=njWwyynLrdo
Diveflyfish demonstrates the opposite polarity current coming from two axial disks pressed together in opposition. This is how I assume Jerry Bayles has his twin axial polarized disks configured.
I think this helps explain the formula:
TOPOLOGICAL CHARGE+MAGNETIC FIELD=CHIRALITY+POLARIZATION.
Even though these two magnet disks are spinning together at the same rate, one is generating more current of an opposite value then the other!
synchro1
Here's a good video on the Faraday paradox from Scotty 7129:
http://www.youtube.com/watch?v=IlUY3snoWI8
"You can't spin light by spinning a lens".
synchro1
Another good video by HPGO2 showing that the field does not rotate with the axial polarized magnet disk when spun on it's axis:
http://www.youtube.com/watch?v=XSWwrvT_c8w
synchro1
@Quotes from Gravityblock on the "Faraday Paradox thread" explaining  what we're calling Homopolar Chirality:
"The disc on the left side is looking at the magnet's face from the east.  The disc on the right side is looking at the magnet from the west.  They are looking at the magnet's face from opposite directions, thus they will be moving through the magneticfield in opposite directions since the magnetic fields are stationary and are not rotating with the axis.  This is why you can't use the axle's direction of rotation to determine the direction the discs will be moving relative to the stationary magneticfields".
"If you're attached to the disc on the left side and looking at the magnetic field or the magnet's face, you will notice you are moving CW through the magnetic field.
If you're attached to the disc on the right side and looking at the magnetic field or magnet's face, you will notice you are moving CCW through the magnetic field.
Even though both discs are rotating in the same direction as the axle, each disc will be rotating through the magnetic fields in opposite directions.
The EMF isn't determined by the rotation of the axis.  The EMF is determined by the direction the disc is moving through the magnetic field.  Moving through the field CW will produce an opposite polarity than a disc moving through the field CCW".
With that understanding in view, let's move forward and discuss the "A" vector potential!
