0 Members and 66 Guests are viewing this topic.
gyulasun
Quote from: synchro1 on July 14, 2015, 10:31:34 AM
@Guyla,
I've seen pictures of the kind lash wrapped Bifilars over threaded zinc screws etc. you guys slapped up for the magnetic field test. That kind of crap won't ring. There's no way you can get the single wire coil to permanently magnetize the nail as strongly as the Bifilar does.
I knew more about the Bifilar coil then "Tesla-Coil-Builder" before I encountered his instructions. The test dosen't work the way he described. I figured out a way to get it to work. Wrap a tight Bifilar on a smooth surface iron nail, snap chage it to ring, set it aside over night, and magically a permanent magnet will appear! This has nothing what-so-ever to do with your failed "retard" tests.
An A.C. sine wave does the work on the nail. The Bifilar is an A.C. electro-magnet! The coil works in resonance and in combination with sine wave current at the Bifilar's self resonating frequency. The self oscillation is generating an A.C. signal. What sence does it make to run D.C. current into it? People will be astonished by the A.C. magnetic strength from the Bifilar if they apply the correct current.
The resonating coil is generating it's own native magnetic field. We get to magnify it with synchronous current. Mystery solved. The "Scrap Yard Magnet". An industrial bulwark for over a century.
Hej synchro1,
You are very good in writing scientifically-sounding bla-bla for the gullible readers, collecting it from the internet or from elsewhere.
And this goes on as the weeks, months or years pass while you have never shown anything which proves your bla-bla.
Go ahead and prove your theories by demonstrating your device which works as in your imaginary science world.
In fact, the problem is not really your bla-bla text but that you have not shown a convincing test with correct measurements for years on your setup.
Gyula
PS  At least you could spell my name correctly...
synchro1
Quote from: gyulasun on July 14, 2015, 02:18:12 PM
Hej synchro1,
Gyula
@Gyula,
Sorry about the misspelling. I had to make a special trip to the hardware store once with a tester magnet to shop out the strongest attracting nail. I asked you to try and produce one for yourself. What have you done?
The oscillating magnetic field of a Bifilar, shock charged into resonance, will impart a permanent magnetic field to an iron core. Do you have a problem with this?
All you need to do come up with is a good nail to try it. You want laboratory findings from me?
gyulasun
Quote from: Magluvin on July 13, 2015, 09:55:26 PM
Is there any speculation as to if the 'RT' is possibly responsible for the efficiency measured, or is there something else in the system that is more questionable as to the outcome?
Just wondering if the motor is needed at all.
Mags
Hi Mags,
Tinman wrote that it is the two bucking magnetic fields which may give an extra kick to the rotor (one field is the one created by the coil B on the stator and this field has the same pole the rotor segment nearest to the stator in that moment just has.  The moment he shorts coil B, an enhanced field is created in the stator segment which may give the extra kick when interacting with the like poled rotor field.
And yes, he mentioned the MEG as the possible motionless setup variant for his working principle, so a motor would not be needed.
Gyula
gyulasun
Quote from: synchro1 on July 14, 2015, 02:30:36 PM
@Gyula,
I finished this topic with you on the nail cored electromagnet in my last mail to you above.  This is an off topic here.
Gyula
synchro1
Quote from: gyulasun on July 14, 2015, 02:43:38 PM
Gyula
@Gyula,
Do you feel I misrepresented you when I quoted you as saying that; Tesla drove the Bifilar with A.C. current at self resonant frequency? Don't you agree that these ubiquitous pulsed D.C. current tests are non-germane?
