0 Members and 63 Guests are viewing this topic.
Spilled Fluids
Quote from: Pirate88179 on July 19, 2015, 06:46:59 PM
Wind is nothing more than solar energy.  Unequal heating and cooling of the earth's surface creates wind.  Wind is just another delivery vehicle for solar energy. Gravity is a closed system and no additional energy can be extracted from it and be made to perform work.
Upon reading about this, I discovered that the main use for gravitational waves will likely be to 'see' into parts of the universe where electromagnetic waves cannot penetrate.
Also it is reported that the energy of gravity waves is infinitesimally small; in fact so small as to be insignificant on earth,
Quote from: tinman on July 19, 2015, 07:29:52 AM
Just as i thought,you have no answer,and thus you hide behind babble.
I have shown you how a PM increases the work that can be done with a set amount of power.
No other material you can come up with will increase the work being done against that spring with a set amount of power as show in my simple experiment.
Like all other self acclaimed guru's,you fail at providing a simple answer,and the reason is-you have none.The electrical power remains the same,and yet the work done against the spring is increased simply by adding a PM into the system. You deny the outcome,and yet you have no argument against it.
Nonsense, like usual you are not accounting for the waste heat.
When you add the magnet, more of the supplied electrical energy is used to pull on the spring, and less is lost do to waste heat.
It like saying that the system goes from 28% efficient to 35% efficient when you add the magnet.  It's meaningless and the magnet was not a source of energy at all.
tinman
Quote from: Spilled Fluids on July 19, 2015, 04:04:56 PM
The PM is a red herring in this experiment. Think of a motorcycle slip streaming a semi transport truck. Then think of a bicycle doing the same. Do you honestly think that the motorcycle or bicycle actually do work that makes the truck go faster(it would actually cause more drag since part of the stream would be disrupted)?
Then why would a PM, ferrite or steel bolt do that when attracted the a powered electromagnet in this bogus experiment?
the only bogus here is you SF. I proved you wrong in regards to the stored energy within the ball being the energy used to give that ball it's second bounce,and i can prove you wrong with your little truck/bicycle/motor bike rubbish as well.
Below is a picture of my rig-would you like to debate this drag bullsh-t thing further?.
Spilled Fluids
Quote from: tinman on July 19, 2015, 07:28:05 PM
You have proven nothing; even the more experienced here have said so.
I'm not interested in debating with a poser.
As the sharks say when they are dismissing money seekers with nothing worth buying...I'm Out!
tinman
Quote from: Spilled Fluids on July 19, 2015, 04:21:15 PM
Agreed but this one was setup to specifically try to make me look wrong...he failed and so far I don't see he has learned anything.
I on the other hand, learned a couple of new things so it wasn't a complete loss  ;D
I proved you wrong in regards to your bouncing ball,and your too chicken sh-t to explain as to where the extra force comes from in regard to my experiment-->and i can prove you wrong with your motorcycle placing drag on the truck bullsh-t as well.
In fact,you are full of bullsh-t,and you know it.
