Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
MarkE
Quote from: pomodoro on August 12, 2015, 08:45:42 AM
Replicators, assume that the powerful magnetic field is being modulated by some unknown force, the plates of the capacitor pick up this modulation and the diode bridge rectifies the AC into DC.
Obviously, an oscilloscope attached to the wires before the bridge will see some kind of alternating voltage not of high frequency (the 0.01uF will short out high frequencies).
This is where one of Professor Lewin's lectures at MIT is instructive.  We can induce voltage across a wire that at DC would have zero or very little voltage drop.  If we interrupt that wire with a capacitor we can induce voltage across the wire in one direction until the capacitor charges and then we can do the same in the opposite direction.  The assumption that has not been established is what is the voltage potential versus time seen right across the capacitor as this could be quite different as what is seen across the FWB input about a foot away.
QuoteWithout the electrolytic,  this voltage will be quite large.  In fact, the rate of charging was quite high on the Doc's videos, so either this voltage is huge and the impedance of the source high, or it a voltage of a few volts with a modest impedance. There has to be a peak voltage of at least what the electrolytic levels out to.
Agreed.
QuoteThe oscilloscope earth clip should not be attached directly, but use a high value resistor in between, to avoid unbalancing the 'generator' and turning the other half into a pickup antenna for low frequency noise. If you do this, at least you can see if the modulation is the 6oHz in your house, or something unexplainable.
The impedances could be high enough that any ordinary oscilloscope probe will load the circuit under test excessively.
I guess I'm getting too carried away here, first we need a working replication. Hopefully the Doc will provide us with some oscillograms soon.
I would like to see a spectrum analyzer sweep using a loop antenna oriented in the same plane as the disc capacitor to FWB wire loop.
synchro1
synchro1
This video looks legitimate. He generates power in the coil positioning the magnet field on the perpendicular. Nothing in line with the axis:
https://www.youtube.com/watch?v=IoRLuhdZnEs
MarkE
Quote from: synchro1 on August 12, 2015, 06:28:43 PM
At about 20 seconds in the oscilloscope displays a high amplitude distorted sine wave.  The caption and DMM read 25V.  You are not going to get that from typical electro-smog.
Quote from: MarkE on August 12, 2015, 07:08:14 PM
The video shows a little magnet being spun by a small motor, and the resulting voltage outputs from a couple of coils in various orientations wrt the spinning magnet. There isn't anything unusual being demonstrated in that video, nor anything relevant to the Stiffler claims.  Unless somebody wants to postulate that Stiffler has some huge magnet spinning off-camera at some high rate of rotation.
But Stiffler's secret is much simpler than that.
