Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
MarkE
Quote from: synchro1 on August 11, 2015, 10:14:24 AM
@MarkE,
No physical pressure what-so-ever needs to be applied to the capacitor. Two play token "Dominos" one on each side of the capacitor can entirely transfer all the uneeded pressure away from it and keep it completely protected. The pressure is an unwanted side effect. The Gauss on the collector plates remains intact without any physical pressure on the capacitor. Alternately, the capacitor may be hard to crush.
The diisc capacitor's 1 1/3'  in diameter and the disc magnet 1 1/2"'. That leaves 1/6 " for a pressure collar around the rim to protect the capacitor. A snug fit would work best.
If you have not reproduced Dr. Stiffler's results then I assert it is premature to state what is and is not required to do so.
synchro1
@MarkE,
You haven't been paying attention. We can drill two holes in the side of a plastic pill bottle cap for the electrodes, remove the top and seat the capacitor inside the rim. A thousand pounds of pressure would go unfelt by the capacitor. Ceramic magnets just won't make the cut.
DrStiffler
So everyone does not go off in Left Field on this presentation, the center mass between the magnet chain is ONLY a pickup. What is going on here is totally magnetic as far as the signal pickup. Think a moment can a magnetic field be modulated? Do all magnetic fields intertwine (assuming field lines can attach). Could plain old permanent magnets be used to intercept fluctuations from other varying (including earth) fields and combine (amplify?) them in such a way that energy can be extracted?
No this is far from simple, yet it is not all that complex once on looks in the right direction.
In a week or two I hope to post a new video which goes into detain and also includes charging of a 3F cap.
Take Care and stay reasonable.
All things are possible but some are impractical.
Hoppy
Further experimentation reveals that if I attach a croc clip lead to either of the capacitor leads and hold the metal clip at the other end of the lead, then I can see the same steadily rising voltage as shown in Dr. Stiffler's video, up to around 3V. Connecting the clip directly to my house earth will slowly discharge the capacitor. I suspect that my body is acting as an antenna, receiving EM smog.
Void
Quote from: DrStiffler on August 11, 2015, 12:29:19 PM
Hi Dr. Stiffler. Regarding what I mentioned above:
"It would be very helpful if Dr. Stiffler would show the difference in charge rate with the magnets present compared to the charge rate
with the magnets removed, and also show the charge rates when starting with no magnets and step by step
adding a pair of magnets at a time, and showing the charge rate after each additional pair of magnets is added. "
Since you seem to be saying that the permanent magnets are important to getting the charging results you have shown, doing the above
suggested test steps would help to demonstrate this in a simple way. Will you be willing to demonstrate this? Until you or someone else can show
how much the charge rate varies with and without the magnets present, then it is still not clear at all to viewers of your videos how much effect the
permanent magnets are actually having in your setup.
All the best...
