Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
synchro1
Quote from: MarkE on August 11, 2015, 08:44:26 PM
So would you please provide links to your experiments where you developed voltages in the range of 3V - >6V as Dr. Stiffler has shown?
@MarkE,
Unfortunatly I encountered camera trouble. Where's your video channel?
Void
Quote from: xee2 on August 11, 2015, 09:36:28 PM
Xc decreases as frequency increases, so will have smaller value at higher frequencies.
Right, so the 'input cap' will look more and more like a short at higher and higher frequencies,
and thus less and less likely to develop higher voltages across it at very high frequencies,
assuming we are stilll not missing something important in the way everything is connected up.
A 60Hz mains EM field could still very much potentially be a factor if it is strong enough however.
All the best...
xee2
Quote from: Void on August 11, 2015, 09:52:16 PM
Yes, capacitor and its leads will look like loop of wire at higher frequencies (loop antenna). Does not need voltage to get current - only a changing magnetic field strength.
EDIT:  A voltage is produced in the loop according to Faraday's Law.
MarkE
Quote from: pomodoro on August 11, 2015, 07:48:22 PM
The .01uF cap at  has already an Xc of 16 ohms at 1Mhz. It makes the source of power unlikely be from a high frequency transmitter, especially when many volts are developed.
There is a lot of loop area and inductance in the wiring.  It has yet to be shown that the magnets have much if anything to do with the harvested energy.
MarkE
Quote from: synchro1 on August 11, 2015, 09:48:17 PM
@MarkE,
That's too bad about the video.  Did you document your set-up and experiments?
I don't publish YT videos.
