Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
synchro1
Look at these 4" neo disks and the copper disks above and below the coil. A simple plastic magnet seperator disk, sandwiched between the copper disks and disk magnets turns the unit into a large cap charging power plant. These are the largest and most powerful magnets in the consumer market place. The bifilar coil generates a spontaneous charge between the magnets too.
I didn't record the self charging, through the diode and capacitor because I couldn't believe the very healthy readings were accurate at that point. These are the kinds of magnets and capacitor plates it takes to succeed.
https://www.youtube.com/watch?v=PgcZMojb_-I&list=FLGj-eKaG5_tMGNr_yuLePkA&index=2
MarkE
Quote from: synchro1 on August 11, 2015, 10:45:09 AM
@MarkE,
You haven't been paying attention. We can drill two holes in the side of a plastic pill bottle cap for the electrodes, remove the top and seat the capacitor inside the rim. A thousand pounds of pressure would go unfelt by the capacitor. Ceramic magnets just won't make the cut.
Are you speculating, or have you done this and reproduced Dr. Stiffler's results?
MarkE
Quote from: synchro1 on August 11, 2015, 02:59:50 PM
@ Dr. Stiffler,
Quote:
                           " The center mass between the magnet chain is ONLY a pickup".
That puts the "Tesla Bifilar Pancake Coil" high on the list of good potential pickups, right? That's the one I hit "Paydirt" with!
Why?  You already know the construction of the capacitor:  on each side there is a wire lead bonded to a metal disc and between the two metal disks is a larger diameter dielectric disk.  The mutual inductance between the leads is tiny.
synchro1
Quote from: MarkE on August 11, 2015, 07:00:01 PM
That last video's over 5 years old. You just showed up. This is all "Old Hat" for the rest of us pal! We can see the "Cook Battery" componants here and in the Stiffler set ups.
MarkE
Quote from: synchro1 on August 11, 2015, 07:15:21 PM
Then you shouldn't have any difficulty answering the question of whether you used the arrangement you proposed and reproduced Dr. Stiffler's results.
