real free energy with capacitors thru inductance
Started by jimbo, May 06, 2016, 12:10:35 PM
jimbo
Hello dieter
Sorry not really interested in it do some more bench. Work and post more results  to move your point forward. A better approach is  spintronics just make a box with one end open and the other end with a small hole the only rules are all out side parts in the small hole area must be North the inside of box north  no South exposed to the small hole area .then stack a set of small neo's together to make a rod with a North and South end and then put the North into the hole with a tube like a straw .North exposed to North doesn't make sense but it sucks it in and out the other end fast!!.now design a motor with this .arrangement.
dieter
You didn't have to go off topic, but thanks.
I see you have an amp meter, and I guess you also have a volt meter. Just measure volts (well I guess about 12 to 13) and Amps (in serial between battery and inverter), then multiply and tell us.
Also compare this to a situation in which you use the negative inverter output instead of the earth connection. Is it more or less?
jimbo
Hello dieter
This tec is very old . was used on lyenden jars a precursor to modern caps .the trick is elevated voltages .or potential in other words it's a proven system .the early American father's used it to charge the jars aka caps my take on this is when the caps are in a series like three or four the isolated caps charge by the potential of there environment .just adjusting to the new conditions there trapped into.they become polarized like a battery then I steal the charges from them. A Similitude is a string of nails touching a magnet each mail becomes polarized or magnified but nothing there to extract .or use both use inductance.to achieve the results. A billion hivoltage protons will a tract a billion electrons from the environment earth ground the best.I'm pumping out energy from the earth .or if you get a hold of the ground end you!. .good luck with your work. Ps this works just as well with hivoltage negitve.so from one source a hivoltage POS and neg you can double your energy.it's physics.
Tesluh
Good to see this thread getting some discussion, Jim, my schematic was the same as yours minus the ampmeter and swing switch.  Basically asking if either had a purpose in the circuit other than to measure current or discharge the caps.  Hoping to simply charge the 4 caps first then figure out the best way to use that charge.
dieter
Thanks, seems like I better take a closer look at this old technology then.
