use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
that_prophet
FREE ENERGY IS HERE TO STAY
This a Gift from the God of the Bible = (Ezekiel 1:16)
+ this technology is more than just free energy for now
as this description was taken from a Ezekiel's description of a working UFO motor
so,,, this technology should be able to lead us toward anti-gravity + 1000 mph vectoring
if we just start digging into just how this device works
COME ON GUYS + GALS
WE MUST START EXPERIMENTING
TO FIND ALL OF THE HIDDEN SECRETS
THAT THIS TECHNOLOGY HOLDS
that_prophet
http://free-energy.yolasite.com/ has diagrams of this mech
Description of how to build a GEM = Geometrical Electricity Multiplier <<<free energy machine>>>
---------------------------------------------(motor=generator)-----------------------------------------------
You start with a large (100cm circumference) pulley + you attach a DC motor to the center shaft of it
Then you need at least one small (1cm circumference) mini-pulley, + attach an AC generator to it
(the more the better) = More generators = higher current capability
<<because more AC generators=higher capability of current flow>>
Then you would need to build a framing system to hold the motor + generators in alignment for the belt
This could be made out of whatever you had in supply, (1)-wood + nails + screws, (2)-metal strapping or lengths of metal plates, nuts + bolts + screws. I say that you need a belt, but in reality you could use a strap, elastic, rope or even tied length of string, to connect your large pulley + your mini-pulleys together.
This is GOD 's Gift to mankind + as well as the natural world around us, found in Ezekiel 1:16
Other possible names for the letters of GEM
-   God's Energy Mechanism
-   Good Electricity Maker
This was Given to us way back in Ezekiel's time, yet evil spirits have kept this Gift hidden all these years
-   Just look at how ridiculously simple this technology truly is, and ask yourself just how gullible we were, to not see through the evil spiritual warfare that was hiding it from us.
Re: use pulleys to multiply total # of rotations = AC electricity
think about this, if you use one spark of electricity to rotate a DC motor
connected to a, 1000cm circumference pulley
That gives you 1000cm of moving belt, to run by 1 to 10 mini-pulleys of one cm circumference,
Giving you a return of 1000 to 10 000 units of AC electricity,
now try and tell me that you are not multiplying AC electricity
Torque is not a problem as torque comes from power generation = voltage times current
And we are just winding up massive voltage, (we only need one spark of current to start this running)
Which, by the way, is exactly what we need, massive voltage, to turn over your large drive pulley once
COME ON GUYS + GALS
that_prophet
Think about this, if you use one spark of electricity to rotate a DC motor once, connected to a 1000cm circumference pulley, which gives you 1000cm of moving belt, to run past 1 to 10 mini-pulleys of one cm circumference, giving you a return of 1000 to 10 000 units of AC electricity.
THAT IS ONE SPARK OF DC IN = 1-10 000 CYCLES OF AC ELECTRICITY OUT
(You would have to gain a net increase of power) = seemingly breaking the laws of Thermodynamics
Now try and tell me that you are not multiplying AC electricity, when you are multiplying total rotations
And we are just winding up massive voltage, (we only need one spark of current to keep this running)
Which, by the way, is exactly what we need, massive voltage=(pressure), to turn your drive pulley once
To make this a self powered mechanism,
All that you need to do, is add a full wave bridge rectifier, to convert your AC output
Into a DC output, which you run into your DC drive motor
Then you should be able to tap power off of both your AC+DC motors/generators
If you need more current capability, you could simply add more mini-pulleys + AC generators
that_prophet
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
No, you are wrong, just as you have been every time that you have posted the same nonsense here. I suggest (without any actual hope that you will do it) that you study some textbooks on how pulley (and geartrain) systems work, in terms of rotation rate and power transfer.
