use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
that_prophet
Free AC energy is easy to multiply using mechanical devices like pulleys. You expend one spark of DC electricity to rotate a DC motor with one large 100cm circumference pulley only once, and this gives you 100cm of belt. You then run this 100cm of moving belt through 10 mini-pulleys of 1cm circumference, multiplying your # of rotations by 1000=10X100. If you then attach AC generators to each of the mini-pulleys, you would get a return of 1000 units of AC electricity,,, all for the cost of one spark of DC electricity. That's multiplying your electricity by 1000, as for 1 spark of DC electricity, you can through the use of pulleys, gain 1000 sparks of AC electricity. http://free-energy.yolasite.com/
   Please, somebody build this GEM of an electricity multiplier, either using physical means, or you could build it on an electronic simulator. I happen to have been disabled in an automobile accident, and my hands are too shaky to build it for real. I have been on disability pension ever since, so I cannot afford to purchase an electronic simulator, nor can I find a free one that will do the job. GEM = (Geometrical Electricity Multiplier)
   This simple technology could help save our economies and environments, but it is being hidden by evil spiritual warfare. Just look at the simple logic of this technology, how large pulleys only have to be rotated once, which can be made to rotate mini-pulleys hundreds and even thousands of times. AC electricity is created by rotations, so if you can multiply the rotations by simple pulley mechanics, so can you multiply your AC electricity.
   Torque is not a problem, because torque is caused by power, which is voltage times current. These AC generators are only being used to wind up massive voltage, and practically zero current, as you only need one spark of current output, to drive your DC motor once, to make this a self powered mechanism. Of course you have to add a full wave bridge rectifier, to convert your AC output into your DC input.
that_prophet
GEMs could be used to electrically convert h2o into hydrogen fuel + O2 to have the power of fire
And then have a GEM to convert carbon monoxide or dioxide back into O2 + carbon
That way we could have the instant power of the combustion engine,
Every household could have one or many of these GEM power supplies in it. One for every voltage.
We could even put them in our electric cars + no more plugging your car in to gain a charge from your home power, but we could plug our car in to power your house .
Description of how to build a GEM = Geometrical Electricity Multiplier
<<<free energy machine>>>
--------------------------------(motor=generator)-------------------------------
You start with a large (100cm circumference) pulley + you attach a DC motor to the center shaft of it
Then you need at least one small (1cm circumference) mini-pulley,
(the more the better) = More generators = higher current capability
<<because more AC generators=higher capability of current flow>>
Then you would need to build a framing system to hold the motor + generators in alignment for the belt
This could be made out of whatever you had in supply, (1)-wood + nails + screws, (2)-metal strapping or lengths of iron rods, (3)-plastic rods + glue
I say that you need a belt, but in reality you could use a strap, elastic, rope or even tied length of string, to connect your large pulley + your mini-pulleys together.
Other possible names for the letters of GEM
- God's Energy Mechanism
- Good Electricity Maker
It only takes one spark of DC electricity to rotate a DC motor once. If you attach a 1000cm circumference pulley, this will give you 1000cms of moving belt. If you run this length of belt through 10 mini-pulleys of 1cm circumference, + attach AC generators to them, you would get 10,000 units of AC electricity
THAT'S ONE SPARK OF DC ELECTRICITY IN = 10,000 UNITS OF AC ELECTRICITY OUT
(please try to find a way around this AC electricity multiplier)
Torque is not a problem,,, as these generators are only winding up massive voltage, which is exactly what we need to rotate your drive motor, and practically no current = (only one spark)
This is GOD 's Gift to mankind + as well as the natural world around us
This was Given to us way back in Ezekiel's time, yet evil spirits have kept this Gift hidden all these years
- Just look at how ridiculously simple this technology truly is, and ask yourself just how gullible we were, to not see through the evil spiritual warfare that was hiding it from us.
You can seemingly break the laws of thermodynamics, simply because it does not take 100 times more power to rotate a 100cm circumference pulley than it does to turn a 1cm circumference pulley. They both take the same current = one spark of DC, they only take a slightly greater voltage. You are gaining 100 rotations of an AC generator. The physical resistance only happens when you are taking power out of it = voltage times current times duration of time
havuhung
Hi @that_prophet,
Believe you're paranoid! And will never be in technical applications generate energy!.. ;D
citfta
Since you are so determined to overwhelm everyone with your ignorance and continually misuse quotes from the Bible I am going to follow some advice from Ezekiel.  He said the world at that time was filled with false prophets.  And he said we should never listen to them.  If we can't get someone to ban you and your false doctrines then I guess we just have to follow Ezekiel's advice.
that_prophet
I HAVE BEEN ASKED
If this is so easy, what stops you from building it?
I have not built this myself, because I happen to be poor + disabled, on CPP Dissability, so I cannot pay anybody to build it. That is why I want someone else to build it,,, as my hands shake too bad. If someone were to find me an electronic simulator, I would build it on that.
You can seemingly defeat the laws of thermodynamics,
By using the physical capabilities of rotating a large circumference pulley
To gain massive lengths 100cm of belt from a large circumference pulley + then running that massive length through many mini-pulleys of 1cm circumference
Thereby you are multiplying your rotations by 100 = multiplying AC electricity
This works on the simplest of logic, you use the 100cm of belt that you get from rotating a DC motor once, with a 100cm circumference pulley attached. This only costs you one spark of DC current, and then you run this 100cm of moving belt past 1 to 10 mini-pulleys of 1cm circumference, giving you 100 rotations times the # of mini-pulleys that you attach. If you add AC generators to these mini-pulleys, you would get between 100 + 1000 units of AC electricity,,, all for the cost of one spark of DC current. You have just used the mechanics of pulleys, (not breaking any laws of thermodynamics) to multiply massive amounts of AC electricity.
Torque is not a problem, as torque comes from generating power, P=I x V, which is only generated when you have current=(I) times voltage=(V), and you only need one spark of current to drive your input DC motor, which is practically zero, so zero times massive voltage still equals zero.(or practically zero) = practically no torque
Please realize the dark conspiracy covering this subject, yes this is dirt simple, almost too simple to work,,, yet it does indeed work, you just need the faith to try it. Seriously, just try it out, and you will get to see the workings of one of His Miracles. Please, don't let this miracle be hidden any longer. Let us start using the technology of Ezekiel to change the world for the better.
