Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Quote from: ayeaye on October 15, 2019, 04:56:25 AM
How to say, this drawing is really not a correct depiction of any magnetic field. It is just to show the concept. It doesn't work with the Coulumb model. Coulumb model is like both poles having a separate spherical, that is symmetric field. But a real magnetic field differs from the Coulumb model. And if the field lines are more parallel to the axis between the poles, then there may be enough asymmetry to enable overunity.
ayeaye ,is a compass needle  movement for you " overunity" ? Peregrinus. !
ayeaye
Quote from: lancaIV on October 15, 2019, 05:38:13 AM
I mean doing continuous work, this is what is mostly understood as overunity. Otherwise, dropping an object is likely overunity, the gravitational field does work to increase its speed, true? Then also a movement of a compass needle is overunity, the magnetic field does work, where the energy comes from? But in case of the compass needle the magnetic field doesn't do continuous work, so it's not overunity like it is mostly understood.
Quote from: ayeaye on October 15, 2019, 06:44:25 AM
Is electricity stream by pulsed or alternating current " continuous work". ?
Is the permanent magnet quantum-magnetoelectric work to see like DC,pulsative or alternating  ?
Is a permanent magnet in absolute " continuous work" ,slow motion observation ?
What is the influence " over Curie - temperature" and/ or"lower Kelvin". ? Temperature/ magnetic field strengh ,Temperature/ magnetic flow
Instead 165 Watt only 33 Watt for same output as bicycle drive by same torque and rpm :
only" peakconsume/ inertia" to " average consume" harmonizing ?
https://patents.google.com/patent/DE3931611A1/de
ayeaye
Quote from: lancaIV on October 15, 2019, 07:28:27 AM
No, there the field does not do continuous work, it works a limited time in one direction, this is also the reason why the current is alternating. These electromagnetic processes are very symmetric, it is a question how to break symmetry there.
PS Coulomb model, not Coulumb model, i fixed that before.
https://www.apfelkiste.ch/media/catalog/product/cache/1/image/1000x/dbb748385a9a10925f0976de833f349b/n/e/neodym-magnet-kugel-puzzle-bunt_18_.jpg
From round ( each individual symmetry) to quadratic(  = several body related asymmetry)
Has the electrostatic field and the magnetic field the same direction. ?https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=Wheel&PN=&AP=&PR=&PD=&PA=Donald+kelly&IN=Donald+kelly&CPC=&IC=
From "compass/Earth" to Kelly's " magnetic torque multiplier" wheel. !
And the referring "citing documents" !
