GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
Low-Q
Just keep on repeating yourself Mr. Prophet. The concept will not work, but we do have a good perpetual laugh as long you perpetually keep on repeating yourself ;D
I bet my manhood that you will repeat your idea  :o
Cheers
that_prophet
one guy built 3 different versions, but he will not go public
Sorry, but i do not know how to make this any simpler, than you are only paying for the one rotation of a large 100 cm circumference pulley, and then through simple pulley mechanics, you are getting a return of 100 cycles of electricity. There is no torque problem, as you only need to generate the one single spark of DC current, which is practically nothing, and even massive voltage times practically zero current, is still equal to practically zero power, costing practically zero torque.
This is dirt simple to build, and very inexpensive in parts, but you will all listen to the evil spirits whispering in your ear that it's ridiculous, and never take the small amount of effort + time to build it. Now, if you do actually decide to try this, watch out for the hard times that will come upon you, as evil spirits will fight you the whole way.
Satan + his evil followers have been messing with your mind, to keep you from seeing the simplicity of this. You are only paying for one rotation of a large 100 cm pulley, and then through simple pulley mechanics, you are gaining a return of 100 rotations of a 1 cm mini-pulley. Then if you add an AC generator, you get 100 cycles of AC electricity. All for one burst of DC current.
HOW TO BUILD A GEM
Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier=AC type) free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one large pulley attached to a DC motor, + at least one mini-pulley, (the smaller the better) connected to AC generators, both must be of the same voltage, 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor's needs), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together. This has to be dirt simple + cheap to build, as the people that will need to be built this are the soon coming Tribulation Saints, whom cannot buy or sell. Door closes on treaty signing = 2019.04 - http://my2020vision.yolasite.com/ "know that it's near, even at the door " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
that_prophet
Quote from: Temporal Visitor on August 27, 2017, 03:44:11 PM
Here is why, in case you do not know it;
"HORSEPOWER is the only "POWER" that is capable of driving a conventional alternator/generator on this planet."
What you loosely propose is not capable of providing and does not provide the single thing that is REQUIRED.
yes, but how much horsepower does it take to rotate a free floating AC generating
These are my thoughts = the mini-pulley will turn freely,(as these 100 rotations only need to generate one pulse of DC current) + only building up massive voltage, which is just what you need to crank over your DC motor one single time. There is no torque involved in rotating this mini-pulley, as there is no power being generated. You are only generating massive voltage, as you only need to generate one spark=(small burst) of current + power is generated by voltage multiplied by current=(one small burst)
I say that you only need to generate one spark of current, as that is all that the DC motor needs to rotate one  single time, which rotates a 100 cm circumference pulley, giving you 100 cm of moving belt. This 100 cm of moving belt rotates a 1 cm circumference pulley 100 times. Yes, I know that these DC motors can take more than one pulse of current, but the point still is, that it takes an extremely small amount of current. (3 sparks for a 3 phase motor)
I cannot get the simple parts together to try this out for myself,,, (evil influence) please build this super simple free AC electricity multiplier, as evil forces keep hindering my attempts,,, this seems simple enough in logic = your mini-pulleys turn freely, as you are only winding up massive voltage, which is exactly what you need, to crank over your large pulley once, on a DC motor. There is no torque problem, as you only need to generate one small burst of current, (only a spark to rotate the motor one single time)
PLEASE,,, SOMEONE BUILD THIS SUPER SIMPLE AC ELECTRICITY MULTIPLIER + NOT ONLY HELP THE TRIBULATION SAINTS, BUT OUR WHOLE WORLD = NO MORE OIL MONEY GOING TO TERRORISTS
If you care to: you can read more about that sentence here: http://www.backgauges.com/Gen-E-Sys%20II/power.html
Sparks just will not cut it to keep a POWERPLANT generating POWER.
Yes the screwdriver comment/remark by Pulp is a good clue as to what you missed.
that_prophet
(here is my latest version of my description of how this GEM works) = sorry for having to repeat this, but I can no longer modify my earlier posts
FREE AC ELECTRICITY FROM 1 ROTATION OF A DC MOTOR, with a large 100 cm circumference pulley attached = gives you 100 rotations of an  AC generator attached to a 1 cm circumference mini-pulley <----- TESLA RULES -----> (+ don't listen to the evil torque lie, because there is no torque problem) This is because even though your many rotations are generating massive voltage-(which is exactly what you need=[electrical pressure] to crank over your large pulley the once) you only need to generate one small spark of current, (the amount of current that it takes to crank over the DC drive motor one single time) + power is calculated by multiplying voltage time current. So even massive voltage multiplied by practically zero current, is still equal to practically zero power, costing you practically zero torque =(easy to rotate). [one rotation of DC drive motor is converted into 100 rotations of AC generator]
Multiplying Free AC Electricity is super simple with this GEM-(Geometrical Electricity Multiplier)= AC type of free electricity multiplying mechanism at http://free-energy.yolasite.com/ This is a device that can be easily + cheaply be assembled by using one large pulley attached to a DC-(Direct Current) drive motor, and then you add to same belt at least one mini-pulley, (the smaller the better) connected to an AC generator, and both motors must be of the same voltage. You will also need 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into the DC input for your DC drive motor), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string,(easily fixed with no money by Tribulation Saints) to connect the two or more pulleys together.
This works on the simplest of principles, the principles of basic preschool pulley mechanics, where you only have to pay the small amount of electricity,(only a spark) that it takes to gain one single rotation of a DC motor, with a large 100 cm circumference pulley attached to it. With this one rotation of a large pulley, you can gain a long length of 100 cm of moving belt, which will give you a multiple of 100 rotations of a 1 cm circumference pulley, all from your one rotation of a DC motor. This could be multiplied by as many 1 cm circumference mini-pulleys that you wish to attach to this same belt. Then all that you would have to do is, attach AC generators to each of these mini-pulleys that you choose to attach to the same belt as your large 100 cm pulley, giving you 100 cycles of AC electricity for each mini-pulley that you choose to attach.
You could freely gain 1000 cycles of AC electricity from this single burst of DC current, if you chose to attach 10 mini-pulleys to the same belt/strap, with AC generators attached to each one. Please don't listen to these false worries about torque being a problem, as these mini-pulleys would run free of most any torque, as torque only comes from when you need to generate power. Power is calculated by multiplying voltage time current, and although your many rotations of these mini-pulleys are generating massive voltage, (which is exactly what you need to crank over your DC drive motor), you are in need of only one mere spark of DC current. So, even massive amounts of voltage, when it is multiplied by the almost zero amount of current that it takes to rotate a DC motor once, it would equal out to practically zero power, cost practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by simply adding an AC generator to your mini-pulley, you are actually multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage + practically no current, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor the one time. This one rotation of a large 100 cm pulley, can be easily and freely converted into 100 rotations of a mini-pulley of 1 cm circumference. Since AC electricity is created by rotations, multiplied rotation is equal to multiplied AC electricity.
Pulley's have different circumferences, so one rotation of a 100 cm circumference pulley can easily produce 100 cycles of an AC electricity from a generator attached to a 1 cm circumference pulley. This gets even better if you add additional AC generators attached to more 1 cm  circumference pulleys, gaining you another multiplication factor. If you added 10 X 1 cm circumference pulleys, you could gain a total of 1000 = 100 X 10 cycles of AC electricity, all multiplied by using pulleys from 1 short burst of DC current =(1 spark)= just enough to crank a DC motor over once. Guess what you need as electronic pressure = high voltage = just what your AC generators are winding up.
So, each side of this dual AC + DC power supply perpetually generates more than enough of what the other side needs. The one pulse of DC current lets you crank over your large 100 cm circumference pulley the one time, gaining you 100 cm of moving belt. + This 100 cm of moving belt lets you generate 100 cycles of AC electricity, by simple running it past a 1 cm circumference pulley with an AC generator attached. These 100 cycles of AC electricity create more than enough current=(a single spark) + massive voltage = (electrical pressure) which is just what you need to crank over your DC motor + large pulley the single time.
that_prophet
. This super simple free energy https://free-energy.yolasite.com/ =(AC electricity multiplying technology) of using varying sized pulleys, (pulley mechanics) to freely multiply your total # of rotations. The crazy part about this, is that since AC electricity is created using rotations, then you are actually easily + freely multiplying your total amount of AC electricity cycles. This is done by only paying the single burst of DC current, to crank over a 100 cm circumference pulley once. Then by using pulley mechanics, and running 100 cm of moving belt past a 1 cm circumference pulley, returning you 100 rotations, which by adding an AC generator, this could give you a return of 100 cycles of AC electricity. (rotates easily, because you only need to generate one short burst of current = practically zero) Torque is caused when you generate power, + power=voltage multiplied by current, and since current is practically zero, then power + torque are both practically zero.
. With this AC electricity multiplying mechanism you would be able to gain 100 units of AC electricity, all from the small spark of DC current that it takes to rotate a DC motor one single time. Please don't listen to this fictitious lie about torque being a problem, as there is no torque problem with this mechanism. With these many rotations of your AC generator you are just winding up massive voltage, (which is just what you need to crank over your large pulley the once), as you only need to generate one small burst of current, (or practically zero). Power is voltage multiplied by current, and even massive voltage multiplied by practically zero current, still equals practically zero power, which takes practically zero torque.
-   Your 100 cm large pulley only has to rotate once, which causes your 1 cm mini-pulley to easily spins 100 times = building up massive voltage, which is exactly what your large pulley needs to crank over the one single time. Each side of this mechanism, through pulley mechanics, gives you more than enough of what the other side needs. The long length of belt that comes off of the large 100 cm circumference pulley gives you 100 rotations of your 1 cm circumference mini-pulley. Then your 100 cycles of AC electricity gives you more than enough voltage (electrical pressure) to crank over your 100 cm circumference pulley the one time, and remember, it only needs the smallest amount of current, just a mini-burst, only enough to crank over your DC motor one single rotation, or practically zero.
-   I would use a DC drive motor with a 100 cm circumference pulley + at least one AC motor-generator with a 1 cm circuference pulley as output generators, each one giving you back a return of 100 cycles of AC electricity. SO, FOR ONE SHORT BURST OF DC CURRENT:(only enough DC current to crank a DC motor over one single time = (1 spark), with 10 mini-pulleys YOU COULD GAIN a return of 10X100 =1000 CYCLES OC AC ELECTRICITY
-   The only reason that this super simple free energy technology has been kept under wraps, is because of all the evil spirits using spiritual warfare to hide this simple free energy mechanism. The workings of this AC electricity multiplying mechanism are so simple, that it works as proof of evil spirits working behind the scene's. How else can you explain us not being able to see this simple use of different sized pulleys to multiply the total # of rotations. Now since AC electricity is generated by rotations, you can actually multiply the # of cycles of AC electricity.
-   This works by the simple rotating of one or many 1 cm circumference pulleys many amounts of times, building up massive voltage, which is just what you need to crank over your DC drive motor the one single time. These AC generators would run free of most all torque because even though they are winding massive voltages-(electrical pressure to crank over your DC drive motor once),  you only need to produce the one short burst of current. Since power is voltage multiplied by current, even massive voltage when multiplied by practically zero current, would equal practically zero power + torque.
- The reason that I only deal with a "spark", or short burst of current for my DC drive motor, is that is all that it takes the DC drive motor to rotate once. This one rotation of the drive motor, with a 100 cm circumference pulley attached, gives you 100 cm of moving belt. This 100 cm of moving belt would produced 100 cycles of  AC electricity from an AC generator attached to a 1 cm circumference pulley running off the same belt. This 100 cycles of AC electricity, when run through a full wave bridge rectifier, could easily produce your on short burst of current, and we already mentioned that we were generating massive voltages, more than enough to crank over the DC drive motor one single time.
- How much simpler can you make it, by only inputting the small burst of DC current, and gaining back a return of 100 cycles of AC electricity. How can you not multiply your AC electricity. Are you going to try and tell me that 100 cycles of AC electricity would not be enough, to create one single spark of DC current. This would make this AC + DC dual electricity generating mechanism self powering, and the more mini-pulleys with AC generators attached, the more electrical pressure that you would acquire, to let you draw more current.
- Can't you see how dirt simple this is, to only have to be inputting one single "spark"= super short burst of current into a DC motor, with a 100 cm circumference pulley attached. This would give you 100 cm of moving belt, which if you ran past a 1 cm circumference pulley with an AC generator attached, then you would gain a return of 100 cycles of AC electricity. And don't you dare listen to this evil lie of Satan's, about torque being a problem, because this lie holds no strength. Torque is only caused when you are generating power, and power is your voltage multiplied by current. Yes, your massive rotations of your AC generators are generating massive voltage, you only need to generate one small spark of current, which is practically zero. Even massive voltage when multiplied by practically zero current, equals practically zero power, costing you practically zero torque, which equals free moving AC generators.
- Can you believe how much of an influence that these evil forces have on our society, to be able to hide this super simple GEM – AC electricity multiplying pulley technology from us for all these years. I hope that you can see this GEM technology for the super simple free AC electricity multiplying technology that it is, and are not falling for this ridiculous lie about torque being a problem. This DC drive motor only needs one "spark", or short burst of current to rotate the once, so your total input of power is extremely small, meaning that the total torque needed to rotate these AC generators is extremely small. You only need to input a small burst of current to rotate the large pulley attached to the DC drive motor once, so your output, though producing massive voltage, only needs to produce the smallest amount of current. This means that your total amount of power being outputted is practically zero, costing practically zero torque, meaning that these mini-pulleys + AC generators are running free of most all torque.
