GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
My name is Joe Lynch + I have a pre-school simple way of using pulleys to multiply AC electricity. This can be done by only paying the small amount of DC current, for the single rotation of a DC motor with a 100 cm circumference pulley attached + then you run this 100 cm of moving belt past 10 mini-pulleys of only 1 cm circumference, with free running AC generators attached = you would gain 10 X 100 = 1000 cycles of AC electricity,,, all for the cost of enough electricity to crank over your DC motor once =(a mere spark) These AC generators would run free of most all torque, as torque is caused when generating power, and power is defined as current multiplied by voltage. Even though you may be winding up massive voltage, (which is useful pressure to crank over your large pulley) you only need to be generating one spark of current, (practically nothing) the minimal amount of current that a DC motor needs to crank over once. So, practically zero current multiplied by even massive voltage still equals practically zero power + torque. USING PULLEYS TO MULTIPLY AC ELECTRICITY
These generators+motors should be self-powering. I say this because the long length of belt that comes off of one rotation of your DC drive motor, with a large 10-100 cm circumference pulley attached, when run past a 1 cm circumference pulley with an AC generator attached, should easily be able to generate to small amount of DC current that the drive motor takes to rotate one single time. This is of course after you run the AC output of your generator through a full wave bridge rectifier, to convert your AC output into the DC input you need for your DC drive motor
.   and the many rotations of your AC generator should gain the extra voltage that you would need to crank over your large 10-100 cm circumference pulley the one time.
This uses the long length of belt, which comes off a large 100 cm circumference drive pulley, to multiply the # of rotations to 100 cycles of AC electricity. It does this by running the 100 cm of belt, past a 1 cm circumference pulley attached an AC generator. This pulley arrangement can convert the 100 rotations into 100 cycles of AC electricity.
ARGUEMENTS
-   If you get the torque problem argument = there is no torque involved in rotating this AC generator, as this generator is free running, as it is just winding up massive voltage. Torque is only needed when you are generating power, and power is defined as voltage multiplied by current. The only current you need to be generating to make this mechanism self-powering, is a few mere bursts, only enough to crank over your DC drive motor one single time. When talking about current, this is a simple spark, or practically zero current. Since even massive voltage multiplied by practically zero current, is still equal to practically zero power, which costs practically zero torque.
This Spatial Effect Generator = https://www.facebook.com/SegMagneticsInc/ looks more like the mechanism described as a UFO motor in Ezekiel 1:16, that I confirmed  my Vision of a 10 speed bicycle going uphill in 10th gear + then back downhill in 1st gear was from God,,, and not from evil spirits = http://free-energy.yolasite.com/. I could not build it as this type of complex mechanism, so I decided to go with simple + affordable pulleys with a belt to connect them together. I later found out how evil spirits hate this simple free energy mechanism, and started messing with everything + everybody in my life. Don't believe me, then just try to build this dirt simple, easy + cheap mechanism to build, and just see the hard times that fall on you. You will even find that your friends + family will call you crazy, and start turning against you. I will warn you, that only the strongest Spiritual Warriors should try and build this dirt simple GEM free AC electricity multiplier.
.   HOW TO BUILD A GEM = free energy - (AC electricity multiplying mechanism using pulleys) = found in description of a UFO motor in Ezekiel 1:16 = (this can be any voltage, as long as AC generators and the DC motor are of the same voltage) - Here is GEM = a simple free energy technology for the Tribulation Saints (2nd Door = 2022.49) - Multiplying Free Energy is super simple with this GEM-(Geometric Electricity Multiplier) =AC type free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can easily + cheaply be assembled, by using one 10-100 cm circumference large pulley attached to a DC motor, + at least one of the 1 cm circumference mini-pulleys, (the smaller the better) connected to AC generators, both must be of the same voltage, + 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor), a lot of wire to connect your electrical components together, and a belt, strap, elastic or tied piece of rope or string, to connect the two or more pulleys together.
This does not break the laws of thermodynamics, it simply uses the free laws of pulley mechanics to use a length of belt to convert 1 rotation of a large 100 cm circumference pulley into 100 rotations of a 1 cm circumference mini-pulley . We are using the 100 cm of belt that comes off of your large pulley, to gain 100 free cycles of AC electricity. These 100 cycles of AC electricity cost practically no torque, as they are just winding up massive voltage -(which is just what you need to crank over your large pulley the once), as we only need to generate a few small bursts of current to crank over your large pulley on your drive motor the once. Torque is only needed to produce power, and power is defined by voltage multiplied by current. So no matter how high of a voltage we are generating, when it is multiplied by a few short bursts of current (3 bursts for a 3 phase motor), or practically nothing when we are talking about current, the total is still practically zero power, which costs practically zero torque. That would make this dual power supply mechanism self-powering, so that you could easily just tap power off either or both AC + DC power supplies.
that_prophet
Hello fellow inquisitive one, . . . . . . . . . . . CHRISTIAN AGE ENDS BY 2019.04 = 1st DOOR closing
http://doorschristmustpassthrough.yolasite.com/ Ezekiel 1:16 speaks of a UFO motor as wheels within wheels, + this is a self powering set of motors http://free-energy.yolasite.com/ = This is how I confirmed my Vision of a ten speed going uphill in 10th gear + then back down hill in 1st gear, was from God,,, also the fight I had in trying to get people to see through the evil forces hiding this dirt simple free AC electricity multiplication. Free energy is as simple as imputing one short burst on DC current, to drive a large 100 cm circumference pulley for one single rotation. This would move 100 cm of belt past 1 to 10 mini-pulleys of 1 cm circumference, each with AC generators attached, giving you an output of 100 or 1000=10X100 cycles of AC electricity as an output.
« Reply #1 on: September 17, 2016, 11:37:08 AM »
you can multiply the # of cycles of AC electricity by 100, by only having to pay for one rotation of a 100 cm circumference pulley, + then getting back 100 rotations from every single one cm circumference pulley + generator, that you choose to attach to the same belt as the 100 cm pulley. This way you can multiply your output by even more, as you would get a return of 100 cycles of AC electricity, for every one cm pulley that you choose to attach.
can you believe that I was first came up with this technology between 2000 + 2002, + soon after published it on the web @ http://free-energy.yolasite.com/
THANK GOD !!!
I have been trying to tell people about how simple free energy could be,
by using pulleys, we could be freely multiplying AC electricity, or even DC apparently.
Somebody has built one very similar on UTUBE,,,
@ https://www.youtube.com/watch?v=NxpoiCFKmPg
FREE ENERGY IS NOW HERE,,, FOR ALL TO USE FREELY.
No more paying for gasoline,,,,
No more giving terrorists our money.
Prices should start going down, on almost everything
most things that need to be powered by AC + DC electricity, or even fossil fuels should now be made with self powering GEM perpetual power supplies
This should start a massive amount of new free energy inventions.
No more polluting the air we breath, with gasoline engines,,, ALL ELECTRIC AUTOMOBILES.
No more polluting our atmosphere by heating our homes + workplaces = FREE ELECTRICTY
No more pollution for lights + cooking our food = FREE ELECTRICITY
No more paying high electricity bills
Everything should be much cheaper = less shipping costs + practically zero energy costs
GOOGLE "free energy" "using pulleys"
My Ministry websites:
http://my2020vision.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://possibletimingfortribulation.yolasite.com/
http://aliensandghosts.yolasite.com/
http://fire-starter.yolasite.com/
that_prophet
free energy is done using pulleys
you can multiply the # of cycles off AC electricity by 100, if you pay for one rotation of a 100 cm circumference pulley, + then get back 100 rotations of a one cm circumference pulley + generator, that you choose to attach to the same belt as the 100 cm pulley. This way you can multiply your output by even more, as you would get a return of 100 cycles of AC electricity, for every one cm pulley that you choose to attach.
can you believe that I was first given this technology in 2000 or 2001, + soon published it on the web @ http://free-energy.yolasite.com/
THANK GOD !!!
that_prophet
that_prophet
   Free Energy is easily done using pulleys. If you use a large drive pulley of 100 cm circumference, then this would give you 100 cm of moving belt, all for a few cycles of AC electricity, or for a few bursts of DC current. If you run this 100 cm of moving belt past 1 to 10 mini-pulleys of one centimetre circumference, you would gain a multiple of 100 times the cycles of AC electricity for every mini-pulley that you add. So, if you added 10 mini-pulley, then you would gain a multiple 1000, or 10 X 100 cycles of AC electricity.
   This works because it does not cost 100 times as much energy to rotate a 100 cm circumference pulley as it does to rotate a one centimetre circumference pulley. Yet we can get 100 cycles of AC electricity out of the 100 cm of moving belt from only paying for the one rotation of the 100 cm circumference pulley, if we attach an AC generator to the one centimetre circumference pulley. This can be even more significant, by adding additional mini-pulley, because we can multiply our total amount AC electricity, by as many of the mini-pulleys that we add.
