GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
here is GEM =a simple free energy technology for the Tribulation Saints (2nd Door = 2022.49)
HOW TO BUILD A GEM = free energy – (AC electricity multiplying technology using pulleys)
= found in UFO motor in Ezekiel 1:16 = http://free-energy.yolasite.com
(can be any voltage, as long as AC+DC generators/motors are the same voltage)
. Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier) =AC type free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one 10-100 cm circumference large pulley attached to a DC motor, + at least one of the 1 cm circumference mini-pulley, (the smaller the better) connected to AC generators, both must be of the same voltage, + 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together.
. Then you will need to build a framing form out of wood, metal or plastic, to hold your pulleys + motors in the right position to rotate easily. This has to be dirt simple + cheap to build, as the people that will most need to be built this, are the soon coming Tribulation Saints, whom cannot buy or sell without taking the mark. (+ taking the mark means an eternity in hell) The door closes on treaty signing on 2019.04 - http://my2020vision.yolasite.com/ + the door closes for the start of the Great Tribulation on 2022.49. Although it warns us that "the day nor hour knoweth no man", in the same paragraph we are told that we are allowed to, "know that it's near, even at the doors " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
. + There is no torque problem as these massive amount or rotations by the AC generator are like a free running motor, and are the easiest to rotate. The generator rotations are free running as they are just winding up massive voltage, and only need to generate one or a few short bursts of current, (practically zero, when you are talking about current). This is because these 10-100 cycles of AC electricity only need to generate the minimal amount of current, which it takes to rotate a DC motor over one single time. Since torque is caused by generating power, and power is equal to voltage multiplied by current, and the current is practically zero, the total power is equal to practically zero, costing practically zero torque =(free to rotate).
. You can almost think of this generator as a free floating motor, having practically no resistance to rotation at all. This is because for all the 10-100 rotations that this generator does, it only has to produce enough current to rotate your drive motor the one single time. So, you get 100 rotations of this AC generator, to be only having to produce the small amount of current that it takes to rotate your drive motor one single time. That gives you 10-100 to one odds, causing the assurance of this mechanism to be able to run perpetually.
. I figure that this uses massive pulley multiplication to wind up an extremely massive voltage, to the point of which the voltage is so extremely high, that it starts repealing other objects, including the earth = how you get levitation. How can you not multiply your cycles of AC electricity, when you only pay for one rotation of a large 100 cm circumference pulley, and then you get a return of 100 cycles of AC electricity from a 1 cm circumference pulley? Remember, the more cycles of AC electricity that you have, means the more power you are generating.
that_prophet
Pulleys can be used to increase torque, or freely multiply rotations, and since AC electricity is created using rotations of a coil through a magnetic field, you can effectively use pulleys attached to AC generators, to freely multiply AC electricity. You could use one rotation of a 100 cm circumference pulley, to rotate 10 X 1cm circumference pulleys 100 times each, totaling 1000 cycles of AC electricity.
Why can't we use pulleys to multiply cycles of AC electricity, instead of paying for oil to generate it. It would only take one short burst of DC current, to rotate a 100 cm circumference pulley one single time. This would gain you 100 cm of moving belt, which if we ran through any # of 1 cm circumference pulleys, with AC generators attached, then we could gain 100 cycles of AC electricity, for each mini-pulley that we added. With only one mini-pulley + AC generator, that would mean that we could gain 100 cycles of AC electricity, for only the small amount of DC current that it takes to rotate a DC motor one single time. Would this not be a way of using pulley mechanics to generate more electricity,(100 cycles of AC) than you are inputting, (1 short burst of DC current)
I know that you might think torque would be a problem, but torque is in no way a problem. Torque is only generated when you are creating major power, and power is calculated by multiplying voltage by current. Yes, we are winding up massive voltage,(which is just the electrical pressure that we need, to crank over your DC motor with the large pulley attached) but we only need to generate the smallest amount of current to make this unit self powering, (one short burst = only enough to crank the DC motor over once= practically zero). Even massive voltage multiplied by practically zero current, equals practically zero power, which takes practically zero torque = easily rotated.
that_prophet
FREE ENERGY IS THE MOST SIMPLE SECRET,,, THAT I WILL NOW EXPOSE,,,,
YES, TRUMP WILL BE PRESIDENT IN THE START OF THE 7 YEAR PEACE TREATY = THAT MUST START BEFORE THE FIRST DOOR CLOSE = 2019.04 = Gen 51.6 + 1967.44
.   There is a real battle between good + evil going on in this world all around us, and the infamous 7 year peace treaty with Israel MUST start before the first door closes on 2019.04. This is the first of a few doors that we are told that we can know, and in the original Greek, we are even warned that we MUST "know that it is near, even at the doors" –(Mat 24:33). http://my2020vision.yolasite.com/ –(Mat 24:33). Did you ever wonder how we can know that it's near, if we cannot know the day nor hour. What we can know though, is when the door shuts for this to happen within the same generation. This is how we can know that it is near, as we can know when the first door will shut, so that's how we can know that it's near to the door.
.   We are even warned when the Great Tribulation MUST start, and it is before the second door closes on 2022.49, http://doorschristmustpassthrough.yolasite.com/ . This is when we will truly need to use this GEM free energy technology, especially the people in the northern and southern regions of our planet, where the winters are the coldest. We would need this free electricity to keep us warm, as you could not use fires to help keep yourself warm, as the heat and light would give away your position. Please remember, that all of the regular police and army personnel would be against the saints, as they would be run by the global forces, which would be on the side of the enemy anti-christ's. People cannot buy or sell without the MARK + All evil forces will be kicked out of heaven -(1.atmosphere + 2.space + 3.home of God) + sent to our earth. This is when the anti-christ will be killed + Satan will animate his dead body, trying to imitate the resurrection of Jesus.
.   HOW TO BUILD A GEM = free energy - (AC electricity multiplying mechanism using pulleys) = found in description of a UFO motor in Ezekiel 1:16 = (this can be any voltage, as long as AC generators and the DC motor are of the same voltage) - Here is GEM = a simple free energy technology for the Tribulation Saints (2nd Door = 2022.49) - Multiplying Free Energy is super simple with this GEM-(Geometric Electricity Multiplier) =AC type free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can easily + cheaply be assembled, by using one 10-100 cm circumference large pulley attached to a DC motor, + at least one of the 1 cm circumference mini-pulleys, (the smaller the better) connected to AC generators, both must be of the same voltage, + 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor), a lot of wire to connect your electrical components together, and a belt, strap, elastic or tied piece of rope or string, to connect the two or more pulleys together.
.   This works on the simple principle that a 100 cm circumference large pulley does not cost 100 times the amount of electricity to rotate that a 1 cm circumference mini-pulley does. Yet the 1 cm mini-pulley could gain you 100 cycles of AC electricity, where this 1 rotation of the 100 cm pulley would only cost you 1 cycle of AC electricity. This could be multiplied further by simply adding more mini-pulleys, so if you added 10 mini-pulleys to the belt, you could gain 1000 = (10X100) cycles of AC electricity. So, through simply pulley mechanics we could be multiplying the total amount of AC electricity.
.   Then you will need to build a framing form out of wood, metal or plastic, to hold your pulleys + motors in the right position to rotate easily. This has to be dirt simple + cheap to build, as the people that will most need to be built this, are the soon coming Tribulation Saints, whom cannot buy or sell without taking the mark. +(but receiving the mark would condemn us to an eternity in the lake of fire = a place even worse than hell) The door closes on treaty signing on 2019.04 - http://my2020vision.yolasite.com/ + the door closes for the start of the Great Tribulation on 2022.49. Although it warns us that "the day nor hour knoweth no man", in the same paragraph we are told that we are allowed to, "know that it's near, even at the doors " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
.   + There is no torque problem as these massive amount or rotations by the AC generator are like a free running motor, and are the easiest to rotate. The generator rotations are free running as they are just winding up massive voltage, and only need to generate one or a few short bursts of current, (practically zero, when you are talking about current). This is because these 10-100 cycles of AC electricity only need to generate the minimal amount of current, which it takes to rotate a DC motor the one single time. Since torque is caused by generating power, and power is calculated by using voltage multiplied by current, and the current is practically zero, so the total power is equal to practically zero, costing practically zero torque = (which is free to rotate).
.   You can almost think of this generator as a free floating motor, having practically no resistance to rotation at all. So, each side of this AC generator + DC motor paired mechanism will produce more than enough of what the other side needs. You will get 10-100 rotations of this AC generator that gives you massive voltage and since you only needs to produce the smallest amount of current, which it takes to rotate your drive motor one single time. This gives you 10-100 cm of moving belt, to run past one or more of the 1 cm mini-pulleys, with AC generators attached, causing this side of the mechanism to be able to produce more than enough of what the other side needs. This gives you the assurance of this mechanism being able to run perpetually, as each side of this dual power mechanism gives you more than enough of what the other side needs. (you also need a full wave bridge rectifier to convert your AC output back into DC for the input of your drive motor)
http://beliefstoliveby.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
Rapture Quotes = Scriptural references
(Mathew 24:31)          his angels shall gather his elect
(Luke 21:36)               pray that you may be able to escape
(1st  Thes 4:17)           after, we still alive will be caught up with them
(Revelation 3:10)        keep you from the hour of temptation
(Revelation 4:1)          door was open, come up hither
(1st Cor 15:52)            in a flash, in the twinkling of an eye... we shall be changed.
(Titus 2:13)                  while we wait for the blessed hope + the glorious appearing
Paul-R
STEFAN: PLEASE BAN THIS MAN NOW BEFORE YOUR REPUTATION SUFFERS
that_prophet
Are all of you taken in by this evil spiritual warfare,,, mainly the lie about it costing you torque to rotate the mini-pulley with an AC generator attached. This uses the simple principle that it does not cost you 100 times more electricity to rotate a 100 cm circumference pulley, than it does to rotate a 1 cm circumference pulley. Yet if you run the 100 cm of belt past a 1 cm circumference pulley with an AC generator attached, you would gain a multiple of 100 cycles of AC electricity. All of these cycles of AC electricity are produced from the one burst of DC current that your DC drive motor takes to rotate the one single time. Then if you added another two or three mini-pulleys with AC generators, you would gain another 200 – 300 cycles of AC electricity.
   This does not cost you any torque, because even though you are winding up massive voltage, you only have to produce one small burst of current to power your drive motor, which is practically zero. Torque is caused when you are generating power, and even massive voltage when multiplied by practically zero current, is going to equal practically zero power, which costs practically zero torque.
