GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Free Energy is so simple that it can be generate with a large pulley attached to a DC motor, at least one mini-pulley connected to an AC generator of the same voltage, 4 diodes, some wire to connect your electrical components together, and a belt to connect the two pulleys together.
The way this works, is that you are using the 100 cm of moving belt off of one rotation of your large 100 cm circumference, which does not cost 100 times more power to rotate, yet if you run this 100 cm of moving belt past a 1 cm circumference pulley, you would get 100 cycles of AC electricity.
that_prophet
HERE IS A REPLY WITH A LESS RELIGIOUS TONE NTO IT
I would like to share this GEM-(Geometrical Electricity Multiplier) technology with you + the world.
This is a totally free to operate, AC electricity multiplier mechanism. https://free-energy.yolasite.com/
((( NEWS of this ancient technology will change our world ))) Ezek 1:16 from UFO motor description
Free Energy from a GEM perpetual power supply is so simple to build, that it can be generate with a large 100 cm circumference pulley attached to a DC motor, + at least one mini-pulley of 1 cm circumference, connected to an AC generator of the same voltage, 4 diodes - to build a full wave bridge rectifier, some wire to connect your electrical components together, and a belt to connect the two or more pulleys together.
This uses the simplicity of how it does not cost 100 times more power to rotate a 100 cm circumference pulley than it does to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of belt/strap that comes off your single rotation of a 100 cm circumference pulley, past at least one 1 cm circumference pulley that is connected to an AC generator, you can get a return of 100 cycles of AC electricity. This could be done for every 1 cm pulley that you choose to connect to the same belt.
Yes, that's an easy way to gain a multiple of 100 cycles of AC electricity, for each of the 1 cm pulleys connected. The best part is, this can be done from the one single rotation of your DC drive motor, which costs a mere spark of DC current. This "spark" is the small burst of current that it takes to rotate your DC motor one single time. Remember, this DC motor is connected to a 100 cm circumference pulley, giving you 100 cm of moving belt/strap..
Please don't listen to the lies about torque being a problem, as these mini-pulleys run extremely free of torque, as large torque is only caused when you generate massive power. Power is generated by multiplying voltage by current, and though you are generating massive amounts of voltage with your 100 rotations of your AC generator, you only need to generate one small spark of DC current to rotate your DC motor one single time. So, since power is generated by multiplying voltage times current, this would mean that although you are generating massive voltage, it is multiplied by practically zero current, only a spark, which means that you would be generating practically zero power. This would mean that because you do not need to generate practically any power, meaning that you are using practically zero torque. With this single rotation of your DC drive motor, attached to a large 100 cm circumference pulley, giving you 100 cm of moving belt, to rotate your mini-pulleys 100 times each, gaining you massive voltage, and making this mechanism a self powering unit.
The best part about this is, you can get a return of 100 cycles of AC electricity for as many mini-pulleys that choose to attach to the same belt. So if you added 10 mini-pulleys, you could gain a multiple of 1000 cycles of free AC electricity. These mini-pulleys + AC generators would truly run extremely freely, because although you are winding up massive voltage with them, (exactly what you need to crank over your large 100 cm pulley) you only need to generate the one spark of DC current, to rotate your DC drive motor. Torque is caused when generating power, and power is calculated by multiplying voltage times current, so even though you are winding up massive voltage, it is multiplied by practically zero current, so in the end you are generating practically zero power, costing practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by adding an AC generator to your mini-pulley, you are actually freely multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor + large 100 cm pulley the one single time.
Each side of this GEM mechanism gives exactly what the other side needs. The massive voltage that the many rotations of the mini-pulley generates is electrical pressure to rotate the large pulley once, + the one rotation of your large pulley, gives you 100 cm of moving belt that you need to generate 100 revolutions of your 1 cm circumference pulley connected to an AC generator. You will also need a full wave bridge rectifier, (made of 4 diodes) to change your AC output back into DC to power your DC drive motor.
This GEM free electricity generator works on freely multiplying rotations by using the 100 cm of moving belt off of one rotation of your large 100 cm circumference pulley, and running it past at least one 1 cm circumference mini-pulley. Then by simply attaching AC generators to each mini-pulley, you can be freely multiplying 100 cycles of AC electricity, and all for the cost of one spark of DC current. Yes, with this GEM mechanism you can freely multiply any amount of AC electricity, for as long as you would like to continue to let it run.
You will need massive amounts of voltage to crank over your large 100 cm circumference pulley the one single time, yet it costs only one mini-spark of current, because of only having to rotate your large pulley once. This single rotation will give you 100 cm of moving belt, which you can easily pass by any # of 1 cm circumference pulleys with AC generators attached. These mini-pulleys would generate you 100 cycles of AC electricity for each + every mini-pulley that you choose to add, so if you added 10, you would be generating 10X100=1000 cycles of AC electricity. Now, let me point out that you are only putting one spark of DC current into this GEM free energy mechanism, while you are freely gaining 1000 cycles of AC electricity as an output.
This GEM mechanism will rotate these AC generators, freely winding up massive voltage, which is exactly what you need, to gain the electrical pressure to crank over your large 100 cm pulley. These mini-pulleys run extremely easily as although they are freely winding up massive voltage, you only need an extremely small amounts of current, (1 burst to crank over your DC motor once). Because power is equal to voltage times current, and since the current is only equal to one mere spark, or practically zero, and zero times anything is equal to zero, you are not generating much power at all.
This is dirt simple + deals with pure logic,,, you are only paying one spark of DC current, for one rotation of a large 100 cm circumference pulley, and getting back 100 cycles of AC electricity for every 1 cm circumference pulley that you attach with an AC generator, to the same belt or strap that you have going around you large 100 cm pulley. So if you attached 10 mini-pulleys of 1 cm circumference, you would get a return of 10X100=1000 cycles of AC electricity. It is truly that simple, as you can get 100 cycles of AC electricity, for every mini-pulley of 1 cm circumference that you choose to add + all costing you only one mere spark of DC current, (your drive motor is DC, with a 100 cm circumference pulley attached)
There is no torque problem, as the total output that you need to drive your drive motor,(making this a self powering system) is only one mere spark of DC current. These many rotations of your mini-pulleys are just winding up massive voltage, which is exactly what you need to crank over your large 100 cm drive pulley. One thing that you will need to add to this GEM mechanism, is a full wave bridge rectifier, (4 diodes) to convert your AC output back into a DC input for your DC drive motor
+ yes I did get someone to actually build 3 different versions of this, and he said they were dirt simple to build + they all worked great. But he was afraid of the rumors about people that had invented free energy machines being killed soon after, so I not only did not mention his name, but I threw out the stuff he sent me. I did this because I thought that this GEM system was so simple to follow + build, that many others would build it. I did not realize that trying to build this super simple 2 pulley mechanism would bring down the hoards of evil spirits on others, like it did me,,, you will start loosing friends and family, as they first ridicule you, and then turn against you. You will even find difficulties in buying the few parts to build it. (Satan + his demons try to be every wheres )
By the way, I was hoping that you might be interested in how I discovered this new/old free energy technology, so I will tell you where it came from, in this last few paragraphs. The idea on how this super simple preschool pulley technology was, came to me in a Vision, right after I prayed to my Father, and asked Him for a way to help the Tribulation Saints be able to survive the soon coming Great Tribulation. If you do not believe in God or evil spirits, then please explain how this super simple GEM pulley technology was missed for so long.
Evil spirits want us spend a lot of money on fuels to run our lives, and not just to make it harder on us to live, but because the countries that produce most of our oil, have terrorist in them, which one way or another, receive money from this oil revenue. Terrorism is surely a life stile that evil spirits are a follower of, and a method of Satan's choosing.
That's not to mention the pollution that free energy would prevent us from putting into the atmosphere and environment. GEM Free Energy could also easily + at no cost, be reversing our pollution problems, by using electricity to take the carbon + other bad chemicals out of the air that we survive on.
TIME IS SHORT=the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START
before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ + although it warns us that no one can know the day nor hour, we are allowed to know the dates of these doors, as it says in (Mat 24:33) "know that it is near, even at the doors", http://doorschristmustpassthrough.yolasite.com/.
WARNING,,, IF YOU TRY + BUILD THIS GEM MECHANISM, YOU MAY FEEL THE FULL WRATH OF SATAN + 1/3 OF THE ANGELS THAT FOLLOWED HIS EVIL WAYS = because they do not want us humans to have this free energy mechanism, and not spend massive money on oil, which in one way or another gets into the hands of terrorists.
that_prophet
Sorry, but although this idea came to me about 2000-2001, I have not managed to get anything built for it. At the end of my writing I tried to explain the main reasoning for not showing any progress in building a working model of the idea=(spiritual warfare). Not only did everything start falling apart in my life, but it was more than , as friends + family started turning against me. I put this warning at the end of my writing to try explaining the troubles that people will find themselves in, if they were thinking of trying to build this super simple GEM technology, (only an AC + DC motor, a large + a small pulley, 4 diodes, some wire + a belt) they would be fighting against an unknown amount trouble from fallen angels + demons. (evil wants us to keep supporting terrorists by paying for oil)
One other valid excuse that I have for not having a working model for this GEM technology is, that I happen to be a paralyzed man with shaky hands that has no money as I happen to be on Canada Pension. There is also the major hindrance of living in a nursing home, where I cannot have my own set of nail clippers, let alone being able to keep wire cutters + a soldering iron in my room. So, even if I could manage to do the delicate work with my shaky hands, I would not be allowed to have the tools in my room
The closest that I got to a working model of this GEM was my old late 80's P-200 Quickie electric wheelchair. I got them to make my settings the closest to max torq + max speed, and by simply driving uphill fast + going back downhill slow, I could keep recharging my chair, so that I would never have to plug it in to recharge. Even that was not enough proof though, as they soon started telling me that I could not do this for ever, because all that I was doing is wearing out the battery's ability to charge, so eventually I would ruin my batteries. You could have a perpetually running AC generator + DC motor
in union, if you had any electric wheelchair with the settings set to the max + a small hill nearby.
that_prophet
FREE ENERGY FROM 1 ROTATION OF DC MOTOR + 100 cm circumference PULLEY = GIVES YOU 100 ROTATIONS OF AC GENERATOR ON A 1 cm circumference PULLEY ------ TESLA RULES ----- (+ don't listen to the torque lie, as there is no torque problem, because even though you are generating massive voltage-[which is exactly what you need to crank over your large pulley] you only need to generate one mere spark of current, (the amount of current that it takes to crank over the motor one single time) + power is calculated by voltage time current, so even massive voltage multiplied by practically zero current, still equals practically zero power, costing practically zero torque)
Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier)=AC type - free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one large pulley attached to a DC motor, + at least one mini-pulley, (the smaller the better) connected to AC generators, both motors must be of the same voltage, 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor's needs), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together. This has to be dirt simple + cheap to build, as the people that will need to be built this are the soon coming Tribulation Saints, whom cannot buy or sell. The Door closes on the peace treaty signing on 2019.04 - http://my2020vision.yolasite.com/
This works on the simplest of principles, the principles of basic preschool pulley mechanics, where you only have to pay the small amount of electricity,(only a spark) that it takes to gain one single rotation of a DC motor, with a large 100 cm circumference pulley attached to it. With this one rotation of a large pulley, you can freely gain a long length of 100 cm of moving belt, which will give you a multiple of 100 rotations, for your one rotation of a DC motor. This could be multiplied by as many 1 cm circumference mini-pulleys that you wish to attach to this same belt. Then all that you would have to do is, attach AC generators to each of these mini-pulleys that you choose to attach to the same belt as your large 100 cm pulley.
You could freely gain 1000 cycles of AC electricity from this single burst of DC current, if you chose to attach 10 mini-pulleys to the same belt/strap, with AC generators attached to each one. Please don't listen to these fake worries about torque being a problem, as these mini-pulleys would run free of any torque, as torque comes from when you need to generate power. Power is calculated by multiplying voltage time current, and although your many rotations of these mini-pulleys are generating massive voltage, (which is exactly what you need to crank over your DC drive motor), you are in need of only one mere spark of current. So, even massive amounts of voltage, when it is multiplied by the almost zero amount of current that it takes to rotate a DC motor once, it would equal out to practically zero power, cost practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by adding an AC generator to your mini-pulley, you are actually multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage + practically no current, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor once. This one rotation of a large 100 cm pulley, can be converted into 100 rotations of a mini-pulley of 1 cm circumference. Since AC electricity is created by rotations, and more rotations is more AC power, multiplied rotation is equal to multiplied AC electricity.
that_prophet
The simple way that this works is that you are only putting in the small amount of DC electricity to rotate a DC motor one single time, (one spark, or short burst of current) with a large 100 cm circumference pulley attached. Then with the 100 centimetres of moving belt that you get off the 100 cm circumference pulley, and you run it past a 1 cm circumference mini-pulley to rotate 100 times. Then by adding an AC generator to this mini-pulley, you can gain 100 cycles of AC electricity. It is truly that simple, as you only pay for one rotation of a DC motor attached to a large pulley, and you get a return of 100 cycles of AC electricity from a mini-pulley.
The mini-pulley runs free of most all torque, as even though it is winding up massive voltage, it only needs to generate one single spark of current. Torque is only generated when you are generating power, and even though you are generating massive voltage, it is multiplied by practically zero current, (only a spark), equalling practically zero power, which takes practically zero torque to generate. The 100 cycles of AC electricity should easily be able to produce the one spark of DC current that the drive motor needs, making this a self powering mechanism.
Each side of this mechanism gives you more than enough of what the other side of this mechanism needs. The massive rotations of the AC generator gives you plenty of voltage to crank over your drive motor the one single time. Then the 100 cm of moving belt that you get off your one rotation of your 100 cm circumference pulley attached to your drive motor, easily winds over your 1 cm pulley attached to an AC generator 100 times, giving you 100 cycles of AC electricity.
