Utron research
Started by Cherryman, February 02, 2017, 06:25:58 AM
Cherryman
Quote from: conradelektro on February 12, 2017, 02:12:12 PM
Cherryman, thank you for your answers.
Here a web site that is dedicated to Otist Carr:
http://bluestarenterprise.com/
Otist Carr's books, e.g. "Atoms for Peace", can be found here:
http://bluestarenterprise.com/getting-started/
I guess you eventually want to build something like that? (See attached copy from the plans of Otist Carr)
http://bluestarenterprise.com/wp-content/uploads/2014/10/OTC-X1-plans.pdf
I listened some time to the Otist Carr radio interviews. Well,  I am not intelligent enough to learn enough from them to build a flying soucer.
Greetings, Conrad
Tnx for the links, i do know them, but it could help anyone interested to do some reading up.
Also i like to travel my own path, but of course i use sources as well.
By the way,  i'm not building the flying sourcer.  Just its power source.
But who knows, it might take off  ; )
It's not about intelligence in this case, it's about believe.
conradelektro
Quote from: Cherryman on February 12, 2017, 02:19:40 PM
Yes, I heard in the Otist Carr interviews that he is talking about a self energised machine. The spinning cones are supposed to generate their own energy.
Obviously one would want to build one of them first.
About believe: I believe in being skeptical.
Greetings, Conrad
sm0ky2
Quote from: Cherryman on February 11, 2017, 10:30:19 AM
Here is a little update.
I dit a lot of small experiments to get more familiar with the subject and electrics. Maybe i post those little experiments when people like it.
But here is where I'm at now.
Wound my first coil ! : )
http://youtu.be/R7ux__fGEFg
Sorry i took so long to look at this...
I've been rather busy as of late, preparing for a
Relocation
Umm,  not to sound offensive but that coil is all wrong
That is not the instructions Otis gave us.
Take a look at the UFO diagram - notice anything about
That coil?
Step-increments
NOT a smooth cone!!!!
The ratio of #of turns per area is important
This was talked about in great detail by Tesla and Mr. Carr
I suggest you go back and read this information again.
And again, until you grasp the concept.
At the wide end of the coil there is an induction rate
And a #of turns associated with that
At the next step the radius is smaller but there are more #turns
And so on until the very tiny loops at the tip
Square steps, down the cone
Each step having more turns than the one before,
So as to keep a steady induction all the way down.
Cherryman
My "totally wrong" coil just give me 3 volts : )
https://youtu.be/tj6sqq0_WE0
I tested the open coil on voltage while the Utron spins near. I noticed the voltage climbs with the speed, although i feed the Utron DC, i got an ac reading out of the coil. It only works with power on.. so there is somekind of induction going on i guess.
But about it being the wrong coil..  This is exactly the coil i wanted to try first.
But to reassure you, i have some other coil designs in mind.
Rant: Why do i keep those {size} stuff appearing in my texts ?
conradelektro
May be we all get it wrong, Ultron is a Robot:
https://en.wikipedia.org/wiki/Ultron
In the following issue, Avengers #55 (August 1968), the character is identified as Ultron-5, The Living Automaton.
Greetings, Conrad
