Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
shylo
Jack have you tried adding diodes of the opposite polarity to the beginnings and ends ,of your figures 6&7.
Perhaps the new path gives what you call ambient to flow.
I think what people perceive as ambient is just really part of the function of creating flow to begin with.
I don't understand spark gaps, seems like alot of waste to me.
artv
iflewmyown
I'll say one thing, that is the first time I have ever seen an electromagnet coil glowing blue. The next ones will be vacuumed packed in oil.
Garry
ramset
Aliengrey
the thread there is just a mirror to this one,
there are many good fellows there [who read ] and that forum makes a big effort to get new readers.
here is your request again.
http://www.energeticforum.com/renewable-energy/20728-open-source-ambient-harvesting-coil-capacitor.html
it should take you there ,but not much going on yet
respectfully
Chet K
Thanks Grandma
dieter
@Jack, thanks for the update.
@Shylo, spargaps are said to be lossy due to heat etc. But that does ignore some phenomena, such as the Thownsend electron avalange. Teslas abrubtly interrupted arcs are an other example. Current, trying to maintain it's flow. If it can pull in ambient energy to do so, then it will do so.
Also it is a simple square wave oscillator for high voltage. I had a 3kV module running from 2*1.5V batteries (at 2.6V) running the whole night, practicly shortened with the sparkgap.
@all, just a qustion, why are there only 12 threads listed on the home page anymore? it sucks.
NRamaswami
@Jack Thanks for the pdf. I have already tested using much higher power levels and much bigger wires these concepts and a lot of what you have written is true. I have not experimented with the second type of coil that you indicated and so would need to test it. I have pulled in energy from the Ambient field using a different method and it is real.
Spark Gaps disturb the surrounding medium that contains what is called Universal Life Force or Prana. Very high and very powerful output can be extracted when this force is activated. We can get very high Voltage and Very High Amperage both together and a small input alone is needed to achieve it. I have tested them all already. But I had also been told that such frequencies are banned from commercial useage. So has not written about it.
This is one of the rarest times that instead of abusing others a pdf that actually provides open source information of high quality is posted here and the information is genuine. The author who deserves our respect and gratitude apprantly does not have the means to test at high power input levels and that would require multifilar coils of many layers to restrict the input if it is AC due to inductive impedance and high resistance coils if the input is DC.
@Dieter..Can you please send me your circuit. I can have it replicated in future and share what we observe.
Regards,
Ramaswami
