Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
Kator01
Hello Jack,
you might like this guy. He is a scientist. His name is Eugene Jeong
His website
http://dipoleantigravity.blogspot.de/
move down to the embedded vid which is of importance: "physiscs of free energy device" and on to "Tachyonic Universe"
The vid in youtube is here: https://www.youtube.com/watch?v=EB-jWfzkz_E
Definition of self-energy: second sentence of first paragraph
best regards
Mike
Zephir
Quote from: Jack Noskills on February 09, 2017, 07:41:34 AM
Shortly I will describe a simple system that will prove the following items to be true:
1. Ambient energy field exists and it is everywhere.
2. Electrical systems use energy from this field. Unfortunately all access methods to ambient energy field are under unity.
3. Current flow and energy flow are two different things and it is possible to separate them.
4. Current flow through load is not necessary to power it.
5. It is possible to access the ambient energy field using a device that outputs more energy than what is required to operate it.
IMO you're describing Captret device. It probably works rather like the battery
dieter
As far as I see Jacks Capcoils have nothing to do with Captret. Captret turned out to be a voltaic pile battery, as per John Hutchisons analysis.
Jacks Coils are the magnetic twin of the abravmenko plug (or what was his name?). Two secondaries with high capacitance to eachother. One end of each is unconnected. The other two ends are the output (!).
The primary induces a field in the secondaries, despite the fact, that they are connected to something only at one end of each coil. Instead of current flow you get a potential diffrence only. Like in a cap. Then the field collapses, causing a current flow between ground and these open coils. It is at least a 100% reactive.
It's a great pdf, must read.
Zephir
QuoteCaptret turned out to be a voltaic pile battery, as per John Hutchisons analysis
Hutchinson is crazy freak with blurry shaky videos of hanging things lifted by threads. Anyone who is believing, he does "analysis" is even more desperate case than just him. The Captret can really work like the battery, but unfortunately the cheap aluminium oxide capacitors aren't the best way how to demonstrate it. They have large leaking current and of course electrolyte, which corrodes the electrodes. But no battery can charge capacitor to a voltage higher than 3.6 V. Once the voltage increases even more - then you have an effect, which is impossible to explain electrochemically.
dieter
You speak in riddles my friend: I just charged a cap to 7vdc, using a 9v block battery - why shouldn't that work?
Don't wanna go too muchoff topuc, but... anyone who's not a crazy freak is suspicous to me, in a world in which normality is delusive and antisocial.
I doubt he uses threads, but agreed, he szresses the term "zero point energy" a lot in his concrete-fluor (I guess) batteries.
Interesting parallels between his metal desintegration, the real philadelphia project (by navy, shortly after navy plundered teslas vault in 1943) and the "toasted cars" anomaly close to the twins in the 911 incident.
But like I said, lets stay on topic. Maybe you've got a link to the "real" captret effect explained?
kr
