Light Source from MVP (Magnetic Voltaic Potential) by TLG-team
Started by dr.blue, April 05, 2017, 02:47:44 PM
Grumage
Dear Mr. Zephir.
I am well aware, maybe you missed some earlier posts?
What I'm seeing isn't AC, I did oscilloscope tests right at the beginning using a UPS to eliminate any contamination from my industry supply. I saw nothing of an AC nature at all.
My own opinion is that this energy is part of either the Hartmaan or Currie grid system that covers planet earth. As previously stated I was able to partially follow lines and crossings using my dowsing rods.
Kind regards, Mr. Grum.
Zephir
QuoteWhat I'm seeing isn't AC, I did oscilloscope tests right at the beginning using a UPS to eliminate any contamination from my industry supply.
Which oscillograms did you actually measure (link)? Was the signal flat or did it have some AC component? Which amplitude it had? The LED will work with AC/DC signal as well as the UPS, because the UPS contain a rectifying diode at input, which protects the rest of circuit against backward current.
QuoteI was able to partially follow lines and crossings using my dowsing rods.
Do you have some map of these observations with major railways, water mains and power grid lines also labeled? The dowsing rods are sensitive to grid lines and indeed to underground metallic pipes too.
Grumage
Quote from: Zephir on April 08, 2017, 09:15:07 AM
My dear Mr. Zephir.
At the risk of sounding blunt, did you actually understand my previous post?
The UPS that was used in the test was totally isolated, unplugged, sat on an insulative base along with the oscilloscope. I saw no ripple whatsoever.
I'm well aware that dowsing can be affected by many external influences, but......
In my younger days I could actually tell a person what the denomination of coin they had hidden under the hearth rug before it was revealed!!
The " Art " was taught to me as an apprentice by my first employer, the local Water company. It was the only effective means of detecting hidden water mains that were not made of metal.
ramset
Zephir
it is not our first summer here...
you have a knack for stating the profoundly obvious
you have come here with amazing "copy pastes"
which can be found in 5 seconds or less on a google search  [not just talking about this thread
can you offer anything original or unique that fellows here can build or try ?
your act is getting old VERY QUICKLY
after all its not our first summer here we have seen this all before MANY TIMES
all talk no action ??
whats it gonna be ??
Thanks Grandma
Zephir
Quotealong with the oscilloscope. I saw no ripple whatsoever
Why not to send photo or screenshot? Which open circuit voltage you got, which differential resistance it had?
How much current and power you can draw from it? What we are supposed to discuss here actually?
Everyone knows, that he cannot get draw too much power from pipes burrowed in Earth.
Even if it would work in a way unexplainable with mainstream physics, such a way of energy production looks extremely impractical.
You cannot travel with it, the energy/power density/load is low and it will probably corrode the ground pipes soon or later.
Your thread provides no clue how to replicate/falsify it. It even provides no data.
Quoteyou have come here with amazing "copy pastes" which can be found in 5 seconds or less on a google search
So why nobody else (including you) did still post it in this thread?
QuoteThe UPS that was used in the test was totally isolated, unplugged, sat on an insulative base along with the oscilloscope
How did you connected it to your pipes (diagram)?
