The Old Standard Ignition System. Battery. Coil. Points. And Condenser....
Started by Magluvin, October 25, 2017, 07:14:42 AM
Magluvin
Quote from: norman6538 on October 27, 2017, 07:39:01 AM
As a young boy I was told that the purpose of the condenser was to prevents the points
from burning and that is one feature of Tesla's great circuit.
But what the spark plug needs is high voltage to jump the gap
and part of that comes from the primary secondary voltage increase
and part of that high voltage comes from the backemf which is greater than the
battery 12v which goes out of the coil and into the condenser where it gets
recycled again and again so the spark will jump the gap and get repeated
in the resonate circuit many times over.
If you hold your fingers on a 12v battery you will not get shocked but
if you hold each hand to a broken section of a wire and touch them
together and they are powering a coil or motor coil when you disconnect
them you will get shocked because of the backemf because its way over 12v
from the battery.
A very clever and very efficient circuit that works everyday for millions of folks
and for millions of sparks...
But the real question is can we get anything extra out of this circuit like the Bedini
school girl circuit other than the excellent spark we want?
Norman
Have you read the speaker thread?  One more time....'
First we have to start with an already efficient system. Then we apply resonance.  If you did read the other thread, it provides infor on how to increase efficiency beyond 100%, and then we can add resonance to acquire more efficiency.
Have you seen a bedini that outputs more than in?
Mags
Magluvin
Hey MH
Got a lot to do today so cant go over your posts just yet.  Ill be back later to see what you have there.
Mags
tinman
Well,after reading the whole thread,i see that no one as yet has fully explained as to how the simple points ignition system works  :o
Will keep an eye on this thread,to see how long it takes for the whole story to be put together.
Brad
norman6538
No, do not have time today.
One more time....'
No, where is that? thanks
Norman
Mags
norman6538
Quote from: tinman on October 27, 2017, 08:31:07 AM
Brad
Brad, do you know? I pretty much had to teach myself over the years.
Norman
