cheors
Dans cet exemple 36 fils suffisent.
En.  In this example, 36 wires is enough
gotoluc
Quote from: cheors on June 09, 2018, 04:03:44 PM
Merci de partager vos idées de câblage cheors
Cordialement
Luc
En.  Thanks for sharing your wiring ideas cheors
Luc
cheors
Désolé, j'ai fait une erreur, il en faut une cinquantaine.
Sorry, i made a mistake, it  takes about 50 wires
MenofFather
Quote from: gotoluc on June 09, 2018, 02:19:47 PM
Can anyone else think of any other wiring configurations that give isolation using only 36 wires?... please post your ideas and I will try them all and report the results.
Thanks for sharing
Luc
I forgot original Piere  motor windings. So maybe it not correct. But my example of 36 coils and 6 wires.
But my schematic not shows complete isolation coil from each other, if Piere this mean. It only show, that curent not fly in other coils while in one coil is flying direct curent and BACK EMF curent.
pmgr
Luc/Jerdee,
Bias and rotate your coils as I suggested at the end of one of my previous posts:
https://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg522258/#msg522258
Lastly, see what happens if you extend your single North and South poles in your code above to span half of your rotor, so bias coils 1-15 North, 16-30 South and rotate around.
You do not need to modify your stator for this (leave the current 5 slot coil span). No isolation is required either. All your coils remain in series.
The output waveform will not be a perfect sine, but it should give much better results in terms of the amount of power you can get out of the output coil over a load resistor. Use a load of around 250ohms (adjust it to find optimum power transfer). Frequency should be about 30-50Hz and play with the Vdd bias voltage.
PmgR
