Perpetual motion based V track or V gate 3
Started by juliotony, November 03, 2018, 08:15:38 AM
juliotony
gyulasun
Hi Julio,
I answer your post here too, although you posted the same setup in another thread: https://overunity.com/17417/skinner-1939-gravity-machine-centrifugal-force-tests-and-hope/msg526777/#msg526777
And you have got some responses there, this thread you started would be better to discuss.
So the point is that your setup looks 'promising' because the usual sticky spot such magnetic gates have is greatly reduced by gravity (gravitational force stored in a spring).
As Norman said in the other thread: go for it   i.e. build it.
Gyula
Turbo
Hello  I think that spring and weight can be dropped as well
the top magnet needs to be replaced by a switched aircore coil.
Need some external power for start up but once it gets on speed... remove.
Even the simple reed switch will work but a uchip and hall sensor that adjust pulse width will improve efficiency many fold.
gyulasun
Hi Turbo,
It is an interesting simplification you are suggesting. I guess you mean replacing the top magnet with an air core coil I indicated with a green arrow and you did not mean replacing the magnet with the coil I encircled in green, right?
Please clarify, sorry for this dumb question...
My problem is that a coil and permanent magnet interaction always involves Lenz law and there can be no gain there, unless I miss something you really mean but have not mentioned.
Anyway, thanks for your addition, it reminds me of another interesting idea showed by someone many years ago in Stefan Hartmann's earlier yahoo mail group on free energy, see 2nd attachment. Unfortunately, I am not aware of a successful replication of his idea.
Thanks,  Gyula
Turbo
Hello without iron core.
The aircore will not have any sticky point so there is no need to bridge the gap.(at all)
It only needs to be powered to start the thing.
Will start slowly and store kinetic energy and if that gate is good, speed up.
