RANT CAFFE ASYLUM
Started by WhatIsIt, September 06, 2020, 10:09:59 PM
picowatt
EMJ,
I would think you would welcome any suggestions, and the opportunity they provide, to silence the naysayers and prove your claims.
What data can we glean from video #5 at around 7:30?
https://www.youtube.com/watch?v=Tk9uSOdj-hE
A DC power supply is feeding a circuit drawing 17 watts of power as indicated by the DC supply.  The load being driven is a series string of two small incandescent lamps that are rated at 14VDC @.2amps.  Therefore, when the series string is connected across 28VDC, the lamps will draw 5.6 watts at their rated brightness.  There is also an oscilloscope connected to measure the power consumed by the load (the two small incandescent lamps) that is indicating that the lamps are consuming 20 watts.
DC supply indicates 17watts
Scope indicates 20 watts
Lamps indicate 5.6 watts
A good researcher would look at those three indications and want to verify, confirm, and sort out those three indications to either find a measurement error or be proudly able to verify the circuit's claimed operation.
Consider the two incandescent lamps, a good researcher would stand back, look at those indications, and ask themselves "are those two small lamps actually consuming 20 watts as the scope indicates, or even the 17 watts the supply indicates"?  "Can those two small 2.8 watt rated lamps even handle that much power"?
That researcher would want to connect the series string of two lamps directly to the DC power supply and adjust that DC supply until the lamps lit with similar brightness as observed during the POC test.  That researcher would note the power draw indicated by the DC supply and compare that indication to the 17 watts and 20 watts indicated during the POC test.  A very simple 5 minute test.
If it really does take 20 watts from the DC supply to make the lamps illuminate as bright as they were in the video, congratulations, that confirms the scope readings, and the circuit may indeed be operating above unity.
However, if the lamps draw less than 20 watts, or even less than 17 watts, when driven to similar brightness by the DC power supply, that researcher would want to continue sorting it all out.
Regarding the scope indication, a simple test has been suggested that ensures the scope math is programmed to indicate real power using two square waves.
A researcher should welcome any such suggestions, particularly if the tests proposed use equipment the researcher already has and requires little time to perform.
If the scope reads zero power when the two square waves are out of phase, another step has been made toward confirming above unity operation.  If the scope does not read zero power, that would indicate the scope math is incorrect and efforts should be made to sort that out.
Surely you can see the logic in the above discussion.
PW
FriskyFritz
thank you Stefan  ;)
I warned Die silly boy
I told him he was breaking rules
we will eat sausages now
Fritz
Quote from: FriskyFritz on September 15, 2020, 03:46:03 AM
Terms and Conditions
« on: September 15, 2008, 12:40:28 AM »
1. Introduction
The Website Owner, including subsidiaries and affiliates ("Website" or "Website Owner" or "we" or "us" or "our") provides the information contained on this website or any of the pages comprising the website ("website") to visitors ("visitors") (cumulatively referred to as "you" or "your" hereinafter) subject to the terms and conditions set out in these website terms and conditions, the privacy policy and any other relevant terms and conditions, policies and notices which may be applicable to a specific section or module of this website.
2. Information on the Website
Whilst every effort is made to update the information contained on this website, neither the Website Owner nor any third party or data or content provider make any representations or warranties, whether express, implied in law or residual, as to the sequence, accuracy, completeness or reliability of information, opinions, any share price information, research information, data and/or content contained on the website (including but not limited to any information which may be provided by any third party or data or content providers) ("information") and shall not be bound in any manner by any information contained on the website. the Website Owner reserves the right at any time to change or discontinue without notice, any aspect or feature of this website. No information shall be construed as advice and information is offered for information purposes only and is not intended for trading purposes. You and your company rely on the information contained on this website at your own risk. If you find an error or omission at this site, please let us know.
3. Trade Marks
The trade marks, names, logos and service marks (collectively "trade marks") displayed on this website are registered and unregistered trade marks of the Website Owner. Nothing contained on this website should be construed as granting any licence or right to use any trade mark without the prior written permission of the Website Owner.
4. External Links
External links may be provided for your convenience, but they are beyond the control of the Website Owner and no representation is made as to their content. Use or reliance on any external links and the content thereon provided is at your own risk. When visiting external links you must refer to that external websites terms and conditions of use. No hypertext links shall be created from any website controlled by you or otherwise to this website without the express prior written permission of the Website Owner. Please contact us if you would like to link to this website or would like to request a link to your website.
5. Public Forums and User Submissions
The Website Owner is not responsible for any material submitted to the public areas by you (which include bulletin boards, hosted pages, chat rooms, or any other public area found on the website. Any material (whether submitted by you or any other user) is not endorsed, reviewed or approved by the Website Owner. The Website Owner reserves the right to remove any material submitted or posted by you in the public areas, without notice to you, if it becomes aware and determines, in its sole and absolute discretion that you are or there is the likelihood that you may, including but not limited to -
5.1 defame, abuse, harass, stalk, threaten or otherwise violate the rights of other users or any third parties;
5.2 publish, post, distribute or disseminate any defamatory, obscene, indecent or unlawful material or information;
5.3 post or upload files that contain viruses, corrupted files or any other similar software or programmes that may damage the operation of the Website Owner's and/or a third party's computer system and/or network;
5.4 violate any copyright, trade mark, other applicable Germany or international laws or intellectual property rights of the Website Owner or any other third party;
5.5 submit contents containing marketing or promotional material which is intended to solicit business.
5.6 All original content posted by a user becomes "public domain knowledge" and can not be patented anymore.
5.7 Hartmann Multimedia Service does have the right to compile summary articles from the forum postings
for easier reading and summary purposes.
5.8 Hartmann Multimedia Service does have the right to compile archival CD/DVDs for database storage and
distribution to people which have weak online access just charging work expenses and shipping charges.
No charges will be made on the content.
5.8 Content which was posted to the forums can be edited for changes or typos for 1 hour.
After this period you must post a new message to update your postings.
This ensures the verification of timing events and prevents data misuse and data manipulation at
a later time. If a user wishes to delete his content after this 1 hour period he has to apply
by email for it.
( If you are not sure, if you want to have a posting to stay in the forum, please donÂÃ,´t post !)
6. Specific Use
You further agree not to use the website to send or post any message or material that is unlawful, harassing, defamatory, abusive, indecent, threatening, harmful, vulgar, obscene, sexually orientated, racially offensive, profane, pornographic or violates any applicable law and you hereby indemnify the Website Owner against any loss, liability, damage or expense of whatever nature which the Website Owner or any third party may suffer which is caused by or attributable to, whether directly or indirectly, your use of the website to send or post any such message or material.
7. Warranties
The Website Owner makes no warranties, representations, statements or guarantees (whether express, implied in law or residual) regarding the website, the information contained on the website, your or your company's personal information or material and information transmitted over our system.
8. Disclaimer of Liability.
The Website Owner shall not be responsible for and disclaims all liability for any loss, liability, damage (whether direct, indirect or consequential), personal injury or expense of any nature whatsoever which may be suffered by you or any third party (including your company), as a result of or which may be attributable, directly or indirectly, to your access and use of the website, any information contained on the website, your or your company's personal information or material and information transmitted over our system. In particular, neither the Website Owner nor any third party or data or content provider shall be liable in any way to you or to any other person, firm or corporation whatsoever for any loss, liability, damage (whether direct or consequential), personal injury or expense of any nature whatsoever arising from any delays, inaccuracies, errors in, or omission of any share price information or the transmission thereof, or for any actions taken in reliance thereon or occasioned thereby or by reason of non-performance or interruption, or termination thereof.
9. Use of the Website.
The Website Owner does not make any warranty or representation that information on the website is appropriate for use in any jurisdiction (other than Germany ). By accessing the website, you warrant and represent to the Website Owner that you are legally entitled to do so and to make use of information made available via the website.
10. General
10.1 Entire Agreement.
These website terms and conditions constitute the sole record of the agreement between you and the Website Owner in relation to your use of the website. Neither you nor the Website Owner shall be bound by any express tacit or implied representation, warranty, promise or the like not recorded herein. Unless otherwise specifically stated these website terms and conditions supersede and replace all prior commitments, undertakings or representations, whether written or oral, between you and the Website Owner in respect of your use of the website.
10.2 Alteration
the Website Owner may at any time modify any relevant terms and conditions, policies or notices. You acknowledge that by visiting the website from time to time, you shall become bound to the current version of the relevant terms and conditions (the "current version") and, unless stated in the current version, all previous versions shall be superseded by the current version. You shall be responsible for reviewing the then current version each time you visit the website.
10.3 Conflict.
Where any conflict or contradiction appears between the provisions of these website terms and conditions and any other relevant terms and conditions, policies or notices, the other relevant terms and conditions, policies or notices which relate specifically to a particular section or module of the website shall prevail in respect of your use of the relevant section or module of the website.
10.4 Waiver.
No indulgence or extension of time which either you or the Website Owner may grant to the other will constitute a waiver of or, whether by estoppel or otherwise, limit any of the existing or future rights of the grantor in terms hereof, save in the event or to the extent that the grantor has signed a written document expressly waiving or limiting such rights.
10.5 Cession.
The Website Owner shall be entitled to cede, assign and delegate all or any of its rights and obligations in terms of any relevant terms and conditions, policies and notices to any third party.
10.6 Severability.
All provisions of any relevant terms and conditions, policies and notices are, notwithstanding the manner in which they have been grouped together or linked grammatically, severable from each other. Any provision of any relevant terms and conditions, policies and notices, which is or becomes unenforceable in any jurisdiction, whether due to voidness, invalidity, illegality, unlawfulness or for any reason whatever, shall, in such jurisdiction only and only to the extent that it is so unenforceable, be treated as pro non scripto and the remaining provisions of any relevant terms and conditions, policies and notices shall remain in full force and effect.
10.7 Applicable laws.
Any relevant terms and conditions, policies and notices shall be governed by and construed in accordance with the laws of Germany without giving effect to any principles of conflict of law. You hereby consent to the exclusive jurisdiction of the High Court of Germany in respect of any disputes arising in connection with the website, or any relevant terms and conditions, policies and notices or any matter related to or in connection therewith.
10.8 Comments or Questions.
If you have any questions, comments or concerns arising from the website, the privacy policy or any other relevant terms and conditions, policies and notices or the way in which we are handling your personal information please contact us.
11. Copyright
11.1 It is forbidden to post copyrighted material. You can only post your own material
where no third party has any rights on it.
By posting your own original material you waive the rights to any copyright and you agree
to put it into the public domain. Then it is not anymore patentable.
11.2 All changed template graphics, buttons, icons, logos, layouts and look & feel, which are changed from
standard templates, are the copyright of Hartmann Multimedia Service, unless expressly acknowledged as otherwise.
11.3 The data mining, extraction or utilisation of product information from our website is not permitted without our express prior written permission.
Keywords - Website Legal Documents
legal, legal documents, website legal documents, privacy policy, privacy notice, copyright notice, terms and conditions, terms of use, hosting, terms, conditions, agreement, website documents, legal docs, disclaimer, law, trademark, free website legal documents, commitment, information, data security
What is the logic and target from this circuit ?
The efficiency from lamps as indicator :
                                                        lumen per Watt
lamps rated Watt : 2,8 Watt
2 lamps = 5,6 Watt
Charging with by  some assumed 17,8 Watt ' pure power" ~ 17,8 Wh hourly consume !
                                               5,6 Watt lamps lumen output / 17,8 Watt
                                                            lumen/Watt circuit  ratio ?
battery + lamps       versus battery + circuit + lamps   ' dura-cell like' teste for comparison !
Duration before and after !
Sincerely
p.s: ramset his heatbox teste configuration is well mind ,but :
between industrial same rated Watt-age devices are physical-technical output differences
Reference : terrarium hobbiists their heat bulbs comparison study
between lamp rated Volt-age/tension and used upper/lower Volt-age is a non-linear output as lumen and heat relationship
picowatt
Quote from: EMJunkie on Today at 07:28:17 AM
Well, to accurately measure the Power in the Circuit, we must Average the Instantaneous Voltage over time, and Average the Instantaneous Current over Time, this product is the Total Power during this time Period in this Circuit. Right? Do we agree?
This is incorrect.  If you program the scope to the above math, the scope will not indicate real power to the load.
You should instead multiply the instantaneous voltage by the instantaneous current, and then average that product.
Programmed as you describe, the scope would not read zero watts in the suggested "two square wave test" when the square waves are out of phase.  That is why that two square wave test was suggested as a quick test of the scope's math programming.  Programmed as I suggest, the scope will read zero watts when the two square waves are out of phase.
Perhaps CaptainLoz will perform the POC test again using the two series incandescent lamps as the load, note the supply and scope readings, and then drive the lamps to comparable brightness directly from the DC supply and note the power draw from the supply.  If the scope measurements do not agree with the "directly driven from the DC supply" measurements, consider reprogramming the scope math.
PW
picowatt
Quote from: EMJunkie on Today at 07:55:39 AM
Oh Picowatt, come on!
You are saying EXACTLY the same as I said!
That is not true.  You said:
"Well, to accurately measure the Power in the Circuit, we must Average the Instantaneous Voltage over time, and Average the Instantaneous Current over Time, this product is the Total Power during this time Period in this Circuit. Right? Do we agree?"
You appear to be stating that you should average the voltage, average the current, and then multiply those two averages together.
I said:
"You should instead multiply the instantaneous voltage by the instantaneous current, and then average that product."
PW
