LET US ALL HELP RAYMOND BUILD THIS NEW FREE ENERGY MACHINE.
Started by seychelles, April 02, 2021, 11:42:42 PM
Floor
oops, One more typo fix.
I'm not an expert, but I think my observations and calculations are correct.
Some observations.   (with corrections, typo fixes and changes )
1. We don't know the exact lifting height of the 72 coins.
2. A long run time (maybe 10 minutes ? ) will give a more accurate result.
3. An auto counter installed upon the lifter would give an exact count of the number of
times lifted in 1 hour.
Note...
It looks like only 1/2 (one direction) of the the back and forth motion of the
output is being utilized to do lifting.
If this is correct, then the out put is actually 2 times more than is being shown in
the video ?   But then again, using both of these motions will affect the input power
as well.
calculations
1 U. S. quarter dollar coin weighs 5.67 grams
5.67 grams per coin, times 72 coins.
5.67  x  72 =  408.24 grams total lifting per stroke
130 lifts in 103 seconds  =   1.262  seconds per lift
(from 5 minutes and 54 seconds to 7 minutes and 37 seconds in the
video = 103 seconds)
lifting height = 3/8 or 0.375 inch ? (approximation from video, could be way off)
should be measured / stated.
0.375 inch = 0.00952 meter
0.00952  x 130 repetitions = 1.2376 meters
102 grams exerts 1 newton
408.24 grams  / 102 grams = 4.00 newtons
4 newtons x 1.2376 meters = 4.9504 joules in 103 seconds
4.9504 joules / 103 seconds =  0.048 joules per second
                            or
0.048 watts mechanical out put
                           and
0.01 amp x 4.2 volts = 0.042 watts electrical input.
                                IF
Ray's device as presented, is in fact functioning at unity, (that is to say, if my estimation of the
lifting distance of the 72 coins was correct)   ....  note...  typo corrected as 72 coins from 172
                                and
Ray's electric power in, measurements are accurate.
                                then
1. Given that the driving electric motor functions at less than unity, his device
is demonstrating cyclic work from magnets.
2. If the pulley which lifts the coins were made to be eccentric, in such a manner as to
match the       force change   to   distance change      curve of the magnetic forces...
                             then also      (and by consideration of this factor solely)
the device is exhibiting cyclic work from magnets.
3. When the energy expended to cause acceleration against the inertia of the coin mass
is taken into account,
his device is demonstrating cyclic work from magnets.
4. Even if my estimation of the height lifted is an over estimation, it remains to be
seen, whether or not the device is O.U. or can be made more efficient.
seychelles
THE TRUTH WILL SET US FREE. BUT BY THE TIME WE DISCOVER THE REAL
TRUTH NOTHING BUT THE TRUTH WE WOULD HAVE JUST DIE.
SEYCHELLES. KEEP UP THE GREAT WORK FLOOR.
kajunbee
The current draw of the device bounces between.01 and .02 it appears to me. Load/no load current draw.
kajunbee
If someone could verify this then if averaged out your looking at .063 watts.
Floor
Quote from: kajunbee on April 09, 2021, 07:47:20 AM
Definitely there is a fluctuation in amperage early in the video.
At 4 min and 35 seconds in the video, (once the full weight of 72 coins has been loaded )
the amperage has stabilized at 0.01 .
          also
At 5 minutes and  03 seconds when output motion is manually arrested,
1. the amperage drops below 0.01 and
2. the rotating element begins to accelerate.
