Milkovic's Pendulum
Started by Johnsmith, January 11, 2022, 09:36:24 AM
Johnsmith
 An email that I received from Milkovic's research team. With that said, if the designs I post work, they would
be considered as an invention. And if someone does build one of them then credit for the invention would
need to be shared. This is about not giving business a free product.
And with Milkovic, his work is about something like this https://www.youtube.com/watch?v=p9xm9RPVgdw
As he mentions, some people don't have a way to pump water. This is where such work can benefit those
interested as well as those who don't have as it good as some of us.
I also know that some people who might help to invent one of these designs might need the money as well.
It does cost to live and there are some non-profit groups that might raise money to help build these for what
Milkovic has in mind. This is basically mixing capitalism with humanitarianism.
I will let Milkovic's research team know that a perpetually working double oscillation pendulum is a new
invention which is based on his invention and Bessler's work. And that as such, credit will need to be shared.
Otherwise why would someone want to improve an idea at their expense? And it is this thinking that encourages
people to improve upon existing ideas.
What will need to be accepted is that between the builder, myself and Velko the patent rights will need to be shared equally.
Anyone building my design will need to agree with this to prevent greed from taking over. This is because as I said earlier, if
clocks are powered by this then the value of the patent would become worth money. After all, how much energy does a
pendulum clock need to run? Very little is the answer so this concept and the one I'll be posting tomorrow could be scaled down
to power a clock.
Johnsmith
 I went ahead and modified the design so it uses gears. A gear will be placed at the fulcrum for the crossbar. And then
2 lines, one on top and below it will connect to another gear next to the fulcrum of the swinging pendulum. This is where
the math really comes into play. This is because the gears will not be your typical gears. The gear next to the outside
fulcrum will have an axle location that will allow for it to be lifted.
And then after it rotates the swinging pendulum upwards, it will release the gear that controls the swinging pendulum.
And this is if anyone is interested on working on either design, let me know. After all, I am working on Bessler's Wheel
and that is a lot of work as any build is. And for a larger image of the gear type pendulum;
https://photos.app.goo.gl/kTvos5DvcUHVdHt78
p.s., hopefully everyone understands that the images that I've shown are illustrations, are to scale and that with an
actual build dimensions will change. And if these designs work (the math says they will), there are other ways as well.
And as for running a clock with either double oscillation pendulum, they can be scaled down. Think about the Atmos
clock. This would be comparable. This is because it would be difficult to manufacture an inexpensive one. And this
would be where the patent might be worth something. And until that happens it is speculation.
p.s.s., the gear at the fulcrum for the crossbar would not rotate. This is why it would rotate the gear next to the fulcrum
for the swinging weight. And this is where understanding gear ratios is necessary. And with how it is connected to the
other gear, a belt could work. This is where discussing things with the builder on either design will determine how they
are built if someone chooses to work on these designs.
@thx4 and kolbacist, since I was thinking about what you both have done, it is up to both of you if you'd be willing to work with me.
And if not then it will be who is.
kolbacict
Why is oil still not pumped using help of Milkovich's double pendulum?
thx4
Hello John,
I'm finishing this week a proto that I believe in a lot, which uses a principle not far from yours, but simpler, it's about mounting a weight.
It is in the organization of the weights that we are very different.
I can't show you anything at the moment, but at the end of the week we will know. I am associated in the idea with a member that you probably know is Robinhood46.
If my proto falls through you can count on me.
A++
kolbacict
I can't still make a successful Maxwell pendulum in any way.
I would never have thought it would be so difficult.
